0 Coil OK but no Spark??
0 Wheel fitment
5 Tire Pressure?
Last Post: Joe_jeep
6 English newbie
0 Fitting mini apes
Last Post: ivanford
0 .551 Cams in an EFI 1200
0 Forum member mug shots
0 Convert to wide glide front end
Last Post: motorfish
Last Post: BoozeBeast
Last Post: Yakcm2
Last Post: Joe_jeep
0 ultima electronic ignition
0 Power cones
0 S&S MGAL carb
Last Post: thefrenchowl
0 will these fit my 2006 xl 1200c
Last Post: mwXL 2006
0 Noisy
0 93 Sporty Key replacement
0 can you tell me why?
0 Wheels
Last Post: NoRemorse
0 Wont shift from 1st to 2nd
0 Pandemic just got wet!
Last Post: Joe_jeep
Last Post: Oldmxdog61u
Old 9th April 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Default #2 head bolt issue
So I installed my 1250 kit and heads and I had one little issue that's been nagging at me all day today. On torqueing down the bolts I noticed the #2 bolt in the front did seem to always travel as far to click. On the final 40# it clicked immediately. Never moved from the 35# click.
Has me contemplating pulling it and checking it out. The head that is. Only thing tarnishing an otherwise perfect install.
Thoughts?
Old 9th April 2019
Hippysmack's Avatar
On head bolts, if it didn't feel right, it probably ain't right.
Kinda sounds like hydro-locked the cap.
It needs to be stated somewhere to not oil the cap threads but rather lightly oil the studs.
edit:
If the cap bolt did hydrolock, it would effectively be at torque (according to the wrench) early.
It would most likely feel a little spongy while pulling also.
Old 9th April 2019
60Gunner's Avatar
Chief of Security
My thoughts too and against my own advice to you I believe I lightly oiled the cap threads just at the end tho. I knew i shouldve listened to myself. But the manual pretty clearly says to oil.
I'm going to pull them all and start over. Easy enough
Old 9th April 2019
Hippysmack's Avatar
All the threads were cleaned, inspected beforehand?
Try cleaning the caps / studs with brake cleaner.
Lightly oil the studs (lightly meaning as you would see it when purchased from a store).
The oil is to simply allow the cap to glide to torque without grabbing between the threads.
There is no other use for it in operation.
When you start getting up there in torque, watch the bolt heads.
When you relax the wrench, the bolt should not relax with it.
Else the bolt has been stretched and must be replaced.
Those long bolts flex much more in the middle than shorter ones do.
I did the same thing once.....
Won't do it again... on purpose anyway.
The bolt twisted on second to last pull and then twisted back when I relaxed the wrench.
That's the 'didn't feel right' that got me to looking more closely while pulling.
Had to replace it.
edit:
You may also feel like you hit intended torque with a clicker in a sequence but you can go back on that same value and it's a little looser.
You may find the nut will turn a little more at the same value setting on re-check.
You may have too much oil on the stud.
The nut may be tightening when it mingles with the oil, then loosening itself when it has time to squeegee the oil down the shaft... even while you're pulling.
That also feels funny.
Old 10th April 2019
60Gunner's Avatar
Chief of Security
They were thoroughly cleaned. Used a nylon bore brush too. Studs had a light coat of oil with a small brush then wiped off with a clean rag. What did me in was last second guessing and dipped the very corner of a rag in oil and worked it around the bottom half inch of the cap threads. I didn't notice any relaxing going on.
Old 10th April 2019
Hippysmack's Avatar
Good to hear the bolts will hold.
Old 12th April 2019
60Gunner's Avatar
Chief of Security
After some more thought, and talking with Alex @ Hammer, I really don't think it's a hydrolock issue but most likely overshot 35 enough that the initial force of going to 40(final torque on the gasket set instructions) was more. Should be 42 but either way it should be fine.
So basically I could leave it, bump them all to 42, or back them all out and start over.
Old 12th April 2019
hexnut's Avatar
hexnut hexnut is offline
Sportster/Buell Model: Sportster Superlow 1250
Sportster/Buell Year: 2014
hexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond repute
If it was bothering me, I would just re do that one.
2014 Sportster Superlow, Hammer 1250, smash head work, 560 cams, S&S rockers and lifters. ported throttle body and intake,
Hammer crush air cleaner, Barnett clutch
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
Progressive suspension front & rear
Old 12th April 2019
60Gunner's Avatar
Chief of Security
Being as anal as I am I'm going to redo both wth the 42 final.
Re-clean the b!+ch bolts too.
Old 12th April 2019
hexnut's Avatar
If you do remove the heads you can re use the head gaskets. I have several times. Aaron says they re use them in the shop till the finish wears off. LOL
