0 Proper XLCH
Last Post: XL100
0 Turbo Iron 883
0 Ok 1200 to 1275 for street performance
Last Post: SportyHD
0 Andrews N4 VS Stock D or W grind cams
Last Post: vagrant318
0 Momentary starter switch installation question
0 Problem on a trip
0 Michigan Thumb Run:
0 Stock pipes
Last Post: Eric Von Zipper
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 Craigslist
Last Post: Bikeaholic
0 How packed is your garage?
0 No oil flow
0 Reflectors...Yeah, or Neh
0 Where to Buy a Quality Fuel Tank
0 Laughing shotgun pipes...Kickstarter hits pipe
Last Post: cazz1000
Last Post: Joe_jeep
0 Hello from Canada!
Last Post: Piper01
0 Michelin Commander 3
Last Post: ivanford
Last Post: ivanford
0 Cam position sensor
billydale (77), twoqk4you (60), MMILLS69 (46), aaaugie (46), MikeyT (45), chardhin, jjphoto (42), promiscuousman (36)
Old 7th July 2019
djcsportster djcsportster is offline
djcsportster is an unknown quantity at this point
Unhappy electrical system issues
out for a ride on my 95 1220 custom and I noticed that the speedo is not working, turn signal indicators on dash are both lit up and the foot brake pedal won't activate the light. I installed all new circuit breakers but no luck. I cant find a common item in the wiring diagram that would make these all go out at once. Bike starts and runs fine. I'm a decent wrench but the electrical is a definite weak spot for me. Any suggestions would be appreciated
Old 7th July 2019
Toejam503's Avatar
Sportster/Buell Year #2: 1981
Common items causing fault would be: Poor or Loose battery connections, Dirty Grounding points, Ignition Switch either going bad or shorting wires.
Sometimes it helps to shut off the bike and when you turn it back on, wiggle the key.
If you recently did some work on the bike or washed it, check the areas where you did the work. Look for loose or broken connections.
Old 7th July 2019
You can disconnect the TS Canceller & see if the TS lights go out - that will tell you if the signal is coming from the TS Canceller or from some short in the wiring...
You may have scraped the wires under the fender - causing a break in the brake wiring and shorting to the turn signals...
Have you changed/worked on anything at the handlebar switches?
At the tank? At the headlight?
Here are circuit diagrams for the turn signals & the brake light:
http://sportsterpedia.com/doku.php/techtalk:evo:elec03
Old 7th July 2019
Madjak Madjak is offline
Madjak is an unknown quantity at this point
Oil sensor on tranny will make speedo quit n make turn sigs not work properly
