0 can you tell me why?
0 Coil OK but no Spark??
0 Wheel fitment
5 Tire Pressure?
Last Post: Joe_jeep
6 English newbie
0 Fitting mini apes
Last Post: ivanford
0 .551 Cams in an EFI 1200
0 Forum member mug shots
0 Convert to wide glide front end
Last Post: motorfish
Last Post: Joe_jeep
0 ultima electronic ignition
0 Power cones
0 S&S MGAL carb
Last Post: thefrenchowl
0 will these fit my 2006 xl 1200c
Last Post: mwXL 2006
0 Noisy
0 93 Sporty Key replacement
0 Wheels
Last Post: NoRemorse
0 Wont shift from 1st to 2nd
0 Pandemic just got wet!
Last Post: Joe_jeep
Last Post: Oldmxdog61u
Old 12th July 2019
broknluck broknluck is offline
Sportster/Buell Model: 883
broknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud ofbroknluck has much to be proud of
Default Can you Drown a Sportster ???
My 1999 Sportster and me just been through 2 massive cloud bursts in 2 days.One riding about 15 mile the last one it sat out in it for a couple hours.Now there is no start,no crank over but it will Jumper Start but battery drains down.I found one 15 amp fuse blown ,replace it still the same no/go. Do I have something wet like a switch or starter or am I again looking another issue ???
Old 12th July 2019
Hippysmack's Avatar
In my opinion, Harley did a lot for water proofing connectors with the rubber boots on them.
But that didn't moisture proof them.
Connectors that get wet, sit and dry still collect moisture inside the connections.
Start with the wiring down stream of the burnt fuse.
Check all connectors inline from there.
You may find cleaning them and then adding a (small) amount of dialectic grease will help with moisture.
But every cause has an affect.
Too much grease and it can eventually collect dust and you're back in the same boat.
One of my inheritances was a constant blowing of the headlight fuse.
I checked the connectors to find corrosion had grown between them.
I cleaned it, greased it and I've had no problems since.
Old 12th July 2019
Glamazon Glamazon is offline
Sportster/Buell Model: xl883r sold
Sportster/Buell Year: 2014
Ridden mine in Bladerunner style rain from Thornton to Lincoln & all OK, Not like my Honda 500/4 i had in 1976, first sign of damp it was cutting out on 1 o 2 cylinders
Old 12th July 2019
Lincoln's Avatar
Lincoln Lincoln is offline
Sportster/Buell Model #2: 883/1200 project
Sportster/Buell Year #2: 1995
Lincoln is an unknown quantity at this point
That's taking me back... My 400/4 and 550/4 were terrible in the rain (electrics) The R has been sound
Old 13th July 2019
My 2006”R” ,ran its third I.B.A. Saddle Sore 1000, out of Port Huron, Michigan, around lakes ?Erie and Ontario, looping back to Port Huron. We started in rain, had 900 miles of it with 1/4” hail east of Toronto. Didn’t miss a beat the whole 20 hours.
Old 13th July 2019
ever ride florida in monsoon season. wet in the morning and wet in the afternoon. this went on 7 days out of the 9 we rode there.
Old 13th July 2019
Jezebelle's Avatar
Jezebelle Jezebelle is offline
Sportster/Buell Model: XL 1200L
Jezebelle is an unknown quantity at this point
Here is a related question. My 2008 1200xl doesn't have a ocver over the fuseblock? Just the side anel.... shouldn't there be a cover over the fuses to protect from rain?
Old 14th July 2019
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
Mine doesn't have a cover either. I've ridden in 200+ miles of rain at one time , where I had to stop and empty my boots, but the bike never hesitated. I keep the fuse block well lubed with dielectric grease. Other bikes, in the past, I've had to go as far as replacing some of the harness boots because they would collect water and some I would have to blow out ALL the harness connectors with compressed air. Never had a bike take on water in the fuel tank but that could always be a possibility.
Jezebelle: Even tho the fuse block isn't covered, this is the first place to check for corrosion when experiencing electrical issues but it doesn't seem to have moisture problems, otherwise.
Old 14th July 2019
Im beginning to think it may have a different issue than water.I will try to test the Stator ,I replaced the other components recently. Its kinda getting old having an issue with it every couple weeks.It seems to be Dependable ,Dependable on Breaking.....
Old 14th July 2019
harley506d's Avatar
Sportster/Buell Model: 1200c
I think you should change your user name to havingoodluck! might keep the voodoo away!
