0 How packed is your garage?
Last Post: unleashed
0 The Revolution's Rowdy Ancestor?
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Generator removal
0 '81 Gasket/Rebuild Questions
0 Struggling with year??
Last Post: Calcustom
0 oil line routing 79 ironhead
Last Post: bobandy
0 Forum member mug shots
0 THE Hockey Thread
0 4 Speed Stator Replace
Last Post: connorneil13
0 Polished rotor/brake pad compatability
Last Post: Firehawk
Last Post: Firehawk
0 Dynatek Ignition questions
0 compression low?
Last Post: 93trident
0 Hello from the uk I just got my first Harley!
Last Post: Sugarsinner
5 1969 XLCH exhaust question
Last Post: Coz
0 I'm back...
Last Post: screndname
0 Random video thread.
5 RSD LED Indicator
Last Post: mk87ita
DAKSY (68), dwagar (68), DaveDuff (59), chaserband (57), bigcraig74 (46)
motorcycle, motorcycle saddlebags, sportster saddlebags, throw over saddlebags
Old 15th November 2008
ozark ozark is offline
Senior Bike Builder
Sportster/Buell Model: XL
Other Motorcycle Model: 02 SV gone but not forgot
ozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to beholdozark is a splendid one to behold
Default Fitting throw over saddlebags on your motorcycle
About once a day I get an email asking about fitting the bags on a specific bike.
Before we start lets's make sure they will fit:
Let's assume you are interested in throw-overs that measure: 14" WIDE X 7" THICK X 11" TALL
This means that each bag is 16 inches long (measured horizontally), seven inches thick and 11 inches tall (measured vertically)
First Measure from the top of your pipes or chain (if the chain is unguarded), whichever is higher, to the bottom of your seat. You need 12 inches, if the dimension is any less don't buy the bags they are too tall. Don't worry about the shocks. Throw overs go over the shocks. If you have rear turn signals measure horizontally from the turn signal forward. This is where the front of the saddlebags will be. Generally speaking I have found that saddlebags up to 14 inches wide are not a problem.
INSTALLING YOUR SADDLEBAGS
1.. Remove your seat. Most Sportster motorcycle seats are removed by unscrewing the Philips head screw located at the rear of the seat. Slide the seat forward while lifting up slightly to detach the keyhole bracket from the seat post. Then slide the seat to the rear to detach the seat tongue from the rear tank bracket. The process is the same for solo and two-up seats.
2. The yoke is the part of the bags that fits under the seat. Unlace the yoke, position both bags in the location you want them to stay. Overlap one side of the yoke over the other. Using a marker, mark where the yoke lays over any obstructing hardware and the outline of outer edge of the upper yoke where it overlaps the lower wing of the yoke. Note: The saddlebags typically lay over the shocks. Some saddlebags are supplied with an additional yoke extender to be used with extra -wide bikes. This is typically not needed.
3. Lay the bags out flat, place the yoke over a piece of wood, telephone book or something similar. Line the marks up that you made in step 2. The existing holes work for the vast majority of motorcycles.
If the holes don't line up, use an awl, ice pick or drill and make about six holes through both pieces of the yoke. Use the piece of leather strip to lace them together.
NOTE: on most motorcycles it is not necessary to make new holes. Some combination of the existing holes should fit.
4. Place the saddlebags on your bike. Reinstall the seat. Use the lower tie downs to secure the bottom of the bags.
5. Give your bike a final safety check. Make sure the seat and saddlebags are secure and the bags cannot come in contact with your wheel, spokes, belt or chain.
If you have any questions I’m always glad to help. Email : DONC314@HOTMAIL.COM
I have attached photos of a few saddlebags mounted on my 05 XL to give you an idea of how you can mount various saddlebags.
As always don't stab, slice, fold, spindle or mutilate yourself while using sharp instruments!
NOTE:
I have been getting a lot of questions regarding throw over bags fitting various motorcycles. Throw overs are designed to fit your motorcycle without modifying your bike. They typically go over the shocks and in front of the signal lights. Some motorcycle dealers have been telling people that these bags will not fit your bike. They then try to sell you several hundred dollars , sometimes over a thousand dollar set of bags. Measure your bike and decide for yourself! Unfortunately some of these people either don't know or are willing to lie in order to make a sale.
mid30's Avatar
mid30 mid30 is offline
Sportster/Buell Model: 1200r
mid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nicemid30 is just really nice
Very Helpfull wright up.
Old 16th November 2008
scottgearman's Avatar
scottgearman scottgearman is offline
scottgearman is a jewel in the roughscottgearman is a jewel in the roughscottgearman is a jewel in the roughscottgearman is a jewel in the roughscottgearman is a jewel in the roughscottgearman is a jewel in the roughscottgearman is a jewel in the roughscottgearman is a jewel in the roughscottgearman is a jewel in the roughscottgearman is a jewel in the roughscottgearman is a jewel in the rough
bump.... and back to the top you go
A man must consider what a rich realm he abdicates when he decides to become a conformist
Old 1st December 2008
Gary7's Avatar
Gary7 Gary7 is offline
Sportster/Buell Model: XL883 (traded)
Other Motorcycle Model: FXDC Super Glide
Other Motorcycle Year: 2009
Gary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the roughGary7 is a jewel in the rough
Don,
I ordered a set of your throw-overs today on your web site. I should have read the "fine print" before I pulled the trigger because I didn't realize XL forum member's had a 15% discount code to enter at check out.
FoxsterUK's Avatar
Have the blinkers in your pictures been relocated toward the back of the bike?
Fox
Gary7's Avatar
I can answer that. His blinkers are in the stock position. They have not been relocated.
That's one of the reasons I chose his bags. You don't have to relocate the turn signals.
Old 2nd December 2008
Senior Bike Builder
Originally Posted by Gary7 View Post
Don,
No problem,
Your 15% refund has been processed.
I tread very lightly when letting the other forum members know about sales. None of us want the forum to be filled with Spam.
Just a little heads-up for the other members who didn't get Bert's message:
Forum members always qualify for a 10% discount. We are running a 15% off sale on everything in the store even sale items. Just enter the coupon code: xlforum in the coupon field when you check out.
Ride Safe!
Ozark
Old 16th December 2008
Senior Bike Builder
This means that each bag is 14 inches long (measured horizontally), seven inches thick and 11 inches tall (measured vertically)
NOTE:
OOPs corrected 16" to read 14"
Old 31st January 2009
vinnitus vinnitus is offline
Sportster/Buell Model: sportster 883 low
Other Motorcycle Model: kawasaki ninja
Other Motorcycle Year: 2002
vinnitus is an unknown quantity at this point
do you have any pics of how the bags look with a solo seat?
Old 1st February 2009
Senior Bike Builder
I took some a few years ago when my bike had a stock solo. I'll look around and see if I can find them
Ozark
