0 6 speed
Last Post: seajay
0 8th Air Force memorials in the UK
Last Post: 45Brit
Last Post: dewjantim
0 WTB:2003 Tank Badge
Last Post: BlackBikeDave
0 Bought a '74 today.
Last Post: XL100
0 First real ride
0 Tools for a '74 Ironhead
0 Sportsterpedia Progress
0 Brake pedal adjustment on 09 Custom
Last Post: HS125
0 2016 Sportster 1200 Custom No Stage information
0 Leineweber camshaft
Last Post: 11B40
0 forged pistons?
10 Hello from New York
Last Post: bklyngeezer
0 Thanks For The Add / In Michigan
0 hi all
0 Hello from Seattle
0 More oil return questions
Last Post: thefrenchowl
0 Getting Hammered
0 Free***** S&S re-useable filter
Last Post: duffy
Old 21st July 2005
You must remove the spark plugs. And if you get it into 4th/5th gear also it will actually be easy to rotate the rear wheel.
To change gears rotate the wheel until it catches then hold in the clutch and yank on the shifter; repeat for each gear.
It should not be difficut to rotate the wheel.
I would not attempt to find the tightest spot first. It is much more simple to adjust it at whereever it happens to be, then rotate the wheel looking for any spot that is too tight and loosen it there.
Old 21st July 2005
Turbota's Avatar
Turbota Turbota is offline
Racer X ...
I have no idea what year your bike is ... but you don't ever have to take that derby cover off (that large round cover that you stripped the screws out of)
If you have a 04-05, just drain out the tranny fluid after riding the bike. It's got to be hot. Remove the tranny drain plug and get up on it after it stops draining. Move the bike a little right of vertical and then straight up. A little more fluid will drain out. Take your time. Pretty soon, all of the fluid will be removed.
Remove the 2 screws that attach the oval shaped chain inspection cover. Put a plastic funnel in the hole and slowly add exactly 1 Qt of H-D Sport-Trans fluid. Replace the cover ... That's it.
BTW .. the tranny drain plug has a magnet attached to it ... get a rag and remove all the metalic "fuss" from the plug.
As far as adjusting the chain ... you don't remove the derby cover either ... it's done by checking the chain through that same oval shaped cover.
Bottom line ... you don't need to remove the pain in the ass derby cover!
04 XL 1222R
Old 21st July 2005
hero's Avatar
hero hero is offline
Sportster/Buell Model: ex 1200 C rider
Other Motorcycle Model: Dyna Wide Glide
Other Motorcycle Year: 2010
hero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the rough
By 'loading up' I mean slowly increase the preload on the tensioner. No need to have the rear wheel turning or even on a lift. Only the engine running, as the whine is audible with the bike standing still. Might be an even clearer whine if you GENTLY twist the throttle between each turn of the adjuster. Take it for a testdrive after, & take the 2 adjusting wrenches with you, coz if you got it wrong, it's only a matter of slackening the locknut & making a fine tuning. Saved me a lot of time in the past.
Stef.
Old 21st July 2005
Turbota's Avatar
Thanks .......
Old 21st July 2005
MidWest XL's Avatar
MidWest XL MidWest XL is offline
Sportster/Buell Model: 1200 C
MidWest XL is on a distinguished roadMidWest XL is on a distinguished roadMidWest XL is on a distinguished road
Great time-saving tip, hero. Thanks
2003 100th Anniversary1200C - GONE BUT NOT FORGOTTEN
Started out: Silver over Black - Ended up: Black & Chrome
Lowered, HurricaneFlow AC, Black Ceramic V&H Straightshots, and some other stuff
Old 21st July 2005
01Sporty's Avatar
01Sporty 01Sporty is offline
Keep On Keepin' On
Sportster/Buell Model: Pulled to the Darkside
Other Motorcycle Model: FLHTCI
01Sporty is an unknown quantity at this point
Originally Posted by Jeffytune
Dang it SG, you beat me to it....I thought the same thing.
Chuck, that pic looks like beads from the Rio in Vegas or Mardi Gras New Orleans.
C'mon inquiring minds need to know!
No dancin bananas for me TY.
Regards,
Old 23rd July 2005
Racer X Racer X is offline
Racer X is an unknown quantity at this point
Red face
Turbota/Hero,
Thanks for the tips! I'm going to give the primary adjustment a shot this weekend. I'll let you know how it goes.
Have a great weekend!
Racer X
Old 23rd July 2005
Turbota's Avatar
Well, I went out in the garage today and for the first time, I believe my primary chain is correctly adjusted.
I have been complaining for some time now that my chain never was running the correct tension. I have tried to adjust it per the Service manuals procedure a couple of times now ... But I have had no luck at all. I tried adjusting it on a lift and without a lift. Never could get that "tight spot" in the chain right.
Today I didn't use the lift. Got the motor/trans good and hot. Then I put a piece of wood under the jiffy stand to get the bike more upright. Removed the chain inspection cover and started the bike. Left it in neutral ... With the chain spinning like crazy, I could see it slapping all over the place. Adjusted it tighter while it was spinning. Got it where the top of of chain would bounce just a little (but not slapping around like before).
Be aware that a little oil will come out of the inspection hole since the chain gets lots of oil when it's spinning. Maybe lost about an ounce ... not big deal
Cleaned up the oil mess with spray brake cleaner.
Drove the bike .... It's much quieter without any of that "supercharger gear" sound you get with too tight a chain, but it don't clatter like before.
Perfect ... As far as I'm concerned, this is the only way I will ever adjust it again ... You can actually see whats going on unlike the regular way of adjusting it.
I thought I had adjusted the chain correctly before ... but it was way too loose and sloppy.
If you do it like this, make sure the bike is first driven to get it real hot. That chain will tighten the hotter it gets.
Thanks again to "hero" for the info ....
Ron,
Old 23rd July 2005
hero's Avatar
Glad you're happy Ron ! Less time wrenchin' & more time ridin... (& HOW good do those shifts feel eh?? Smooth but solid.)
Be safe
Stef
Old 24th July 2005
xena's Avatar
xena xena is offline
Assistant Administrator
Ron was it easy to detect the whine sound that Hero mentioned? Can I adjust it this way going by the sound alone? I just did my 5k service today and that chain adjustment is the last remaining thing on the list to do so it would be cool if doing it this way works.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
