Snippets
Last Post: sprink
20th January 2022
Posts: 436 Sportster/Buell Model: Ironhead Sportster/Buell Year: 1981 Other Motorcycle Model: 1964 Triumph 3TA
Digital volt meter
Hi,
I am fitting a digital volt meter to my bike, I am wiring the supply wire direct to the ignition, so when I turn the key it comes on.
Should I be wiring some sort of load transistor or something between the meter & the supply side to protect it in case of a voltage surge?
TIA,
Andy.
20th January 2022
Posts: 3,555 Sportster/Buell Model: xls 1000 Sportster/Buell Year: 1980 Sportster/Buell Model #2: xls 1000 Sportster/Buell Year #2: 1983 Other Motorcycle Model: 1200 Chopper XL Other Motorcycle Year: 1990
I.d just wire in a low amp inline car fuse to the hot wire in series and call it a day.
The voltmeter should state specs somewhere so you can figure if 1 or 2 amp is OK.
20th January 2022
Posts: 2,926 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2017 Other Motorcycle Model: BMW R9T Other Motorcycle Year: 2015
Originally Posted by Andy Hog
I am fitting a digital volt meter to my bike...
No.
21st January 2022
A fuse is a great idea, that's on the to do list for tomorrow.
Thank you.
Andy.
21st January 2022
Posts: 10,973 Sportster/Buell Model: 1200s Sportster/Buell Year: 2001 Sportster/Buell Model #2: xlch Sportster/Buell Year #2: 1974
the volt meter is a parallel system and not an inline system. if it is a good brand, then it should have all the protection you need. it probably uses less than 1 amp to function.
the only issue i can see is if your system has excessive ac ripple, the a filter capacitor could be used but then again, system on the machine would be affected also like flickering in the lights.
21st January 2022
Originally Posted by bustert
..the volt meter is a parallel system and not an inline system...
+1
There's virtually no current flowing thru the voltmeter. It just sees voltage. You can hook the voltmeter directly across the battery terminals with no ill effect. Or across the terminals of your car battery that can supply far more current than your bike battery.
23rd January 2022
Well. My Fluke VOM is internally fused to a 9 volt battery.
Up to you.
23rd January 2022
Mine's the same but the OP isn't hooking up a VOM, just a volt meter. The fuse in your VOM keeps you from toasting the meter if you try to do an amperage check using ohms settings or similar.
Reason: sp
27th January 2022
Posts: 463 Sportster/Buell Model: XLH 883 Sportster/Buell Year: 1995 Other Motorcycle Model: Honda CM450 Other Motorcycle Year: 1982
Fuses are for current generally. Volt meters pull very little current. Way, way less than 1 amp, miliamps in fact. You don't need a fuse. If there is a fault that somehow pulls that much current to blow a fuse, then your volt meter is going to be the least of your worries.
The fuse in that Fluke is for current, it has nothing to do with the battery or voltage. Well, if you connected to 1Kv maybe, but under normal circumstances, no.
PS. I repair electronics for a living.
1995 XLH 883 Sportster Hugger
27th January 2022
Posts: 401 Sportster/Buell Model: XL1200T Sportster/Buell Year: 2017
Where will you voltmeter get power from to see the display?
The Fluke and other handheld meters use a battery.
