Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Engine Conversions
0 Oil Pump Hard to Spin
Last Post: Peteroo
0 Putting a 4.5 tank on my Roadster, but I still want it to look like a Roadster.
Last Post: gravydog
0 ‘68 XLCH...transmission
Last Post: DirtyHarry68
0 !975 XLCH advance timing unit
Last Post: roadmut
0 Small B and S stickers?
Last Post: Loony
0 Street tracker
Last Post: stalkie
0 Push Rod Adjustment
Last Post: ezmerf
5 Spark Plugs
Last Post: Bob
0 Bracket class at home track
0 This guy want's to stop.
0 Transferring photos
Last Post: lugster
0 Shuts down after 30 miles
0 where did you put your xlforum patch?
Last Post: tigger
0 Timing issue
0 It's a Buyinhead
Last Post: Magneto Sportster
0 Anyone make a DIY vibrating tumbler?
Last Post: paulc
0 THE Trainspotting Thread
Last Post: Cropduster
Last Post: myrl883
Last Post: Scuba10jdl
0 Re 1986 ignition
Last Post: Edster
0 sommer shootout
Last Post: Racepres
0 900 heads contd..
Last Post: mrmom9r
dtremaine (71), Dana (69), Shorty0064 (54), Mini Sumo (50), bikenest (50), ecjq (47), broncobilly (44), XL883L (41), Captain Awesomepants (39), calfunk (37)
90ci, big bore, engine builder, hammer performance, patriot defender
  #1491
MatHormell's Avatar
Sportster/Buell Model: XL883R
Think he went 103 this pass, I was gaining on him
Originally Posted by jkinkade View Post
well done, great times & speed!!
what speed was your friend on softail doing?
[SIZE="1"]
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HSR 48 Miunki
Conical Valve Springs
S&S Premium Lifters
Dynatek 2000i
WorldWideBearings
Patriot Defender Exhaust
[SIGPIC][/SIGPIC][/SIZE]
A 4 liter V8 eater's Avatar
A 4 liter V8 eater A 4 liter V8 eater is offline
Sportster/Buell Model: 883 Flat Track Racer
Sportster/Buell Model #2: RIP 1200S
Sportster/Buell Year #2: 1999
A 4 liter V8 eater has disabled reputation
Originally Posted by MatHormell View Post
Also got to weight the bike. Its 433lbs with a full tank
I'm glad to hear that. Where do you think most of the weight savings came from?
I have been trying to compensate for my Iron jugs and aftermarket cases, but I have never weighed the bike to see where I'm at. I think my main weight savers are the Lithium battery, XR style tail, Sun rims, Yamaha forks with PM calipers, an aluminum 30 tooth crank sproket, and a titanium front axle. I used to have a compufire starter and aluminum clutch basket which were both slightly lighter than stock. I took out the combination of aluminum basket and compufire fire because the strong starter combined with weak basket starter ring ate up the teeth.
Fingers crossed I'll have an XR1200 crank installed soon too which will save weight. I need to take some measurements of the cases so Aaron can determine if its feasible. My hydraulic press arrives tomorrow.
1999 XL1200S - SE slips ons, SE ignition 5500, 6800 & 7500 RPM (I got worried about the ignition getting discontinued so I bought what I could)
Link to thread on "Harley Racing" events across the country: http://xlforum.net/forums/showthread.php?t=53470
These events include Hillclimbing, Flat Track Racing, Ice racing, Drag Racing, etc.. They are all sports dominated by Harley Davidsons. They are always located in scenic areas and are great weekend rides. The above link allows XLforum users to coordinate riding to these events together.
MatHormell's Avatar
The biggest loss I would say is the wheels first, then front end, swing arm, oiltank/battery, then all thin small cuts here abd there.. the motor weight savings were pretty much canceled out by the cast irons jugs as far as static weight goes. But yea 433 is great and right about what I guesstimated it would be about. This was with a full tank of fuel as well. May go to an aluminum tank and carbon cover to cut a few more eventually
Old 23 Hours Ago
MatHormell's Avatar
Well amazingly things worked out, and I am headed to Kentucky today for the AMRA super street races. Super stoked! A friend Chris M. Is coming 170 miles out of his way from Oklahoma to swing me and the bike up and we are headed out! Can't thank him enough for that, really great guy! Looking forward to meeting a lot of the guys I've known for years but never met.
Will be posting stuff throughout weekend
