0 Oil Pump Hard to Spin
Last Post: Peteroo
0 Putting a 4.5 tank on my Roadster, but I still want it to look like a Roadster.
Last Post: gravydog
0 ‘68 XLCH...transmission
Last Post: DirtyHarry68
0 !975 XLCH advance timing unit
Last Post: roadmut
0 Small B and S stickers?
Last Post: Loony
0 Street tracker
Last Post: stalkie
0 Push Rod Adjustment
Last Post: ezmerf
5 Spark Plugs
Last Post: Bob
0 Bracket class at home track
0 This guy want's to stop.
0 Transferring photos
Last Post: lugster
0 Shuts down after 30 miles
0 where did you put your xlforum patch?
Last Post: tigger
0 Timing issue
0 It's a Buyinhead
Last Post: Magneto Sportster
0 Anyone make a DIY vibrating tumbler?
Last Post: paulc
0 THE Trainspotting Thread
Last Post: Cropduster
Last Post: myrl883
Last Post: Scuba10jdl
0 Re 1986 ignition
Last Post: Edster
0 sommer shootout
Last Post: Racepres
0 900 heads contd..
Last Post: mrmom9r
dtremaine (71), Dana (69), Shorty0064 (54), Mini Sumo (50), bikenest (50), ecjq (47), broncobilly (44), XL883L (41), Captain Awesomepants (39), calfunk (37)
Old 3 Days Ago
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
chevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to beholdchevelle is a splendid one to behold
With 52....?
Old 3 Days Ago
Magneto Sportster's Avatar
Magneto Sportster Magneto Sportster is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1960
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1959
Magneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant futureMagneto Sportster has a brilliant future
#52 goes around the support tube pointing up. #51 goes around the exhaust pipe sticking down. The tabs are facing each other and get bolted together.
"Ride 'em, don't hide 'em!"
Old 3 Days Ago
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Bruce, You are really going after your bike. Looks so different and better. Great job. Yes, 51 and 2 go together as stated.
Ok, now I'm revived
Old 2 Days Ago
thanks guys.i might have those pieces.my main concern is the front pipe.i bought the bracket for that,should have it on tomorrow morning.i had it on once,but it needed to be flipped 180 degrees.
Old 1 Day Ago
I put the mid bracket on the front pipe this morning.maybe i'll post a pic.it's the same side as the other 2 pics.i checked out the location for the mid bracket on the rear pipe,it's only about 6'' away from the rear one.seems unnecessary and overkill.i needed the mid bracket on the front pipe because it got blown off twice when I jump on it hard.donr's port work and the 1-3/4'' R exhaust valves made a big difference in the exhaust flow out of the pipes.
Old 1 Day Ago
if anyone wants to see another pic,speak up.
Old 1 Day Ago
simonster123's Avatar
simonster123 simonster123 is offline
simonster123 is a jewel in the roughsimonster123 is a jewel in the roughsimonster123 is a jewel in the roughsimonster123 is a jewel in the roughsimonster123 is a jewel in the roughsimonster123 is a jewel in the roughsimonster123 is a jewel in the roughsimonster123 is a jewel in the roughsimonster123 is a jewel in the roughsimonster123 is a jewel in the roughsimonster123 is a jewel in the rough
I would be interested to hear from Don on the nature of the porting of the XLR heads.
I'm guessing that they were originally ported by Branch for the factory, and that served them well for TTs and other off-road events of the time?
I am curious as to what was done by him (without giving away too much proprietary info) to the existing port job to change it. What was your stated purpose of the work, Bruce? To gain a faster street machine with power further down the band, or to flow even more air for a stroker, or?
It sure would be interesting to know a bit more about the difference and results of the different styles of porting.
And more pics of that sweet machine certainly couldn't hurt!
Old 1 Day Ago
faster street machine yes,but the mostly the port flow(cfm)needed to be increased to match the larger displacement.Don told me the XLR heads were fine for a 900,but not a 1200.i found the o.e.m. bracket for the rear pipe.maybe I can make that work.it will make the pipe lower which might cause kick lever interference.which is why the bracket I have on there now is on.
Old 22 Hours Ago
i tried the o.e.m. bracket at the end of the rear pipe.no dice.the pipe runs to high for it.the reproduction XLR pipes don't fit as well as the o.e.m.raining this morning,so no riding to work,which means no pic today.maybe tomorrow.
Old 4 Hours Ago
mrmom9r's Avatar
mrmom9r mrmom9r is offline
mrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud ofmrmom9r has much to be proud of
Regarding the head work. It's like Bruce said, the XLR heads are optimized for a 900cc engine.
For a 1200 , 10 to 12 more cfm is required to make good power up to 6500 rpm.
The larger motor also likes a little more port volume. The Branch heads are technically correct shape-wise so it's just a matter of carefully scaling them up for more volume and flow while keeping the width , height , and valve bowl of the ports in proportion .
Sounds simple enough.
