Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Suspension, Frame, Forks, Fuel Tank, Oil Tank, Fenders
0 Jumping and rocking at around 3K rpm
Last Post: northern bobber
Last Post: Model H
0 Oil in air cleaner
Last Post: jazzman
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
0 I guess I'm back
Last Post: gravydog
0 ***DK Custom-Improved Front Suspension w/ Intiminator Fork Valves***
0 ***DK Custom Products is Now offering the Black Headlight Grille***
0 Some oil issues!
0 Battery reversed, bike dead
Last Post: Bow only
10 New to the HD world, Ironhrad vs Shovel, whats the diff
Last Post: shooterj2003
0 Wtb - badlander seat for 1996
Last Post: slamtry
0 Hello from B.C. Canada
10 howdy from australia
0 Manifold -CYLYNDER head connection
Last Post: leon bee
0 1991 frame/engine original ground locations
0 1971 XLCH Project progress
Last Post: Whitewalls
0 Hello from mid Missouri
0 LED Brake light, surprising problem
Last Post: deuce460
Last Post: deuce460
Last Post: deuce460
0 Jockey Shifter on a Right Side Shift Bike?
Last Post: dodgetrucken
3 Wtb, Wts, Wtt, Wtg (XRs)
Last Post: Scott
Old 23rd August 2014
nitrous jim nitrous jim is offline
Sportster/Buell Model: s1
Sportster/Buell Year: 01
Sportster/Buell Model #2: nitrous s1
Other Motorcycle Model: 10 second nitrous shovel
Other Motorcycle Year: 1971
nitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of lightnitrous jim is a glorious beacon of light
Default aluminum oil tank build photos
I like S1 body work so I got a S1 frame off ebay and welded the back of it onto my 2001 m2 so the plastic would fit.
I built this is because I have always wanted to use the end of a mag light as an oil cap. so here it is.
I machined aluminum bungs to fit the stock rubber mounts
I made a sump in the bottom so even if there is very little oil it will be at the pick up.
[IMG]http://[/IMG]
it looks cool with the fender on it, helps cool the oil, holds more than the stock tank, wont puke oil out the vent and I got to finely use that old mag light as an oil cap
the one on the top is the vent. the return sprays the oil at the back of the tank at an angle to help separate the air from the the oil (at the furthest point from the pick up)
Old 24th August 2014
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Model: 88 inch modified
Sportster/Buell Model #2: iforgot
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
wilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to behold
Talking
showoff!
looks great.
Old 27th August 2014
steelworker's Avatar
steelworker steelworker is online now
Other Motorcycle Year: 2016
Great work! Definitely repworthy.
