Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Suspension, Frame, Forks, Fuel Tank, Oil Tank, Fenders
5 Run/Turn/Brake light problems
Last Post: Meko1250
5 Terminology Sticky?
0 Sign of getting old...
0 gas tank paint protection
0 If you don't bring closure to your thread, then the terrorists have won
Last Post: Firehawk
0 12" or 14"? (Apehangers)
Last Post: Nrg2brn
Last Post: Jarlaxle
Last Post: oupa
0 Mainshaft- What happened here
Last Post: moparnut360
0 whats your iron head worth
Last Post: Whitewalls
Last Post: retread08
Last Post: Mr Dream Merchant
6 Is Your SPORTSTER...
Last Post: oupa
Last Post: Kbetts
Last Post: oupa
0 How much should I offer for this 48
Last Post: oupa
5 my 3D printed turn signals.. what would you print?
Last Post: oupa
0 How to start a 1967 Sportster XLCH
Last Post: mjdart
0 Spokes question
pwssr, petefwa, skeeter883 (67), roadogette (66), khaskins (61), iriegnome (54), sportster808 (51), ironheadmax (49), matt275 (44), DJb (43), HDFirefighter (37)
Old 1st February 2014
planesane's Avatar
planesane planesane is offline
Sportster/Buell Model: 1200c
Sportster/Buell Model #2: xl 1200
Sportster/Buell Year #2: 1989
Other Motorcycle Model: x1 lightning
planesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to allplanesane is a name known to all
Default 99 x1 swing arm bearing replacment
has anyone performed a swing arm bearing replacement? if so what does it take I have my bike apart now and want to get it done.
Old 2nd February 2014
dwl25 dwl25 is offline
Sportster/Buell Model: xl 883c
dwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nicedwl25 is just really nice
As I recall no different than any other bearing replacement. Lift bike remove rear wheel, bottom shock mounts and the swingarm. You'll have to drift out the race and drift in a new one with something. I've used a big socket.
I hope this helps.
Dave, Galveston, Texas (formerly Lake Perry, Kansas)
PuddlePirate's Avatar
PuddlePirate PuddlePirate is offline
Sportster/Buell Model: 883 Hugger/Buell XB12
Sportster/Buell Model #2: Electra Glide
Sportster/Buell Year #2: 2002
PuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nicePuddlePirate is just really nice
Search badweatherbikers.com
There are a couple of those documented. Since your bike is already apart it should make things a heck of a lot simpler for you.
Your limits are self-imposed by what you let your mind believe
Old 3rd February 2014
purpony's Avatar
purpony purpony is offline
Sportster/Buell Model: Buell X1 Lightning
purpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to beholdpurpony is a splendid one to behold
Swingarm bearing are the same as steering neck bearings, which are the same as trailer wheel bearings. These can be had cheap at autozone, advanced auto etc.... I got Timkin bearings at autozone.
I used the special tool that worked great on removing them.
http://www.toolsource.com/harley-dav...-p-102081.html
also, just so you know, there have been updates to the front and rear isolators for your bike.. may want to upgrade at least the rears while you have it apart.
planesane's Avatar
Thank you I will look into it all
Old 4th February 2014
purpony's Avatar
is there a number on the bearing seals in your swingarm????
I dont remember which seal i used and from looking around it could be either 34823 or 12192TB....
The Bearing Race part number is L44610 and the Bearing is a L44643
Old 6th February 2014
planesane's Avatar
where can I find the updated parts and how can I tell if I have them already? how are they different?
