0 Trackday Sportster
0 POLL: Vance and Hines
Last Post: Darkseacret
0 1970 sporty, hard to crank
Last Post: doc martin
0 Jutland 05-31-16
Last Post: Akdawg
Last Post: r4fthrs
0 1965 Ironhead in CT
Last Post: forqueue
6 Is Your SPORTSTER...
Last Post: wandrur
0 It's Flame__'s Birthday!
Last Post: 83XLX
0 Hello from NY
Last Post: hexnut
0 THE Trainspotting Thread
0 And so it begins......
Last Post: Rossline
Last Post: Blowupster
0 Mag wheel corrosion
Last Post: shaymus
0 Forum problems???
90ci, big bore, engine builder, hammer performance, patriot defender
  #1501
Old 24th June 2018
MatHormell's Avatar
Sportster/Buell Model: XL883R
Nope no strap, been leaving harder and loosing 60ft time
Originally Posted by cycowrencher View Post
There is more in it if you can get aggressive with the hit. Are you strapped.
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HSR 48 Miunki
Conical Valve Springs
S&S Premium Lifters
Dynatek 2000i
WorldWideBearings
Patriot Defender Exhaust
Old 24th June 2018
cycowrencher's Avatar
Rear air pressure at 20 or lower. You have the power to be in the low teens for air. Also turn up the preload on the back so the tire comes into play before the chassis finishes squatting. If you can preload the front so there is no extension on the hit it will get on the back tire better.
Old 24th June 2018
jcro61 jcro61 is offline
jcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud of
Default HAMMERPerf 90" In the Works
A strap will help keep the front end down. You can buy the strap brackets for your forks like I have. Will help a lot
this isn't just a trend homie, it's a lifestyle...
Old 24th June 2018
MatHormell's Avatar
Bike hasnt lifted a single time yet, left off the limiter today and dropped it, no lift, got a little sponge with forward motion hooked and gone
Old 24th June 2018
MatHormell's Avatar
But yea I'm. May try that next time, going to run without for this event
Old 24th June 2018
Something is bogging you down... you are brave to leave on the limiter which that motor and short wheel base lol
Old 24th June 2018
MatHormell's Avatar
Bike seems to be doing what it should, just need to find its sweet spot
Old 24th June 2018
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
Nice work, no time like seat time. More in there for sure. What division you running?
Old 24th June 2018
MatHormell's Avatar
Super street 7 bikes in the class, here is the first round for tomorrow
I also found some more HP, turned up the timing, took off the air filter, and fed it more fuel, I wasn't as fast on the 60 but made more HP up top, just need to hit a solid 60 and run 128 and I should be right there with Chris around 10.1-10.2
Old 24th June 2018
Vohnsen Vohnsen is offline
God damit thats some great Numbers. A whole second faster than me on the 1/8. Gj man. I follow you on Instagram aswell. I love your Bike
https://www.youtube.com/nikolaiownz - Homemade dragbike with Stock XL1200 '98 engine.
