0 Riding in The Heat!
0 What Petcock
0 Efi and carbs
Last Post: motorend
0 Mandatory Motorcycle Inspections
0 Rear master cyclinder bore size
Last Post: Truckedup
0 head and cylinder painting
Last Post: xlhshawn
Last Post: kkbii
0 Bike lost power,back fired and stalled
Last Post: zack74
Last Post: xena
0 7 Dead and more wounded
Last Post: seajay
0 Primary/gearbox chirp
Last Post: Jesus Jon
Last Post: Knuckles
0 When Were You Born?
0 Robbie's uncomfortable seat theory
Last Post: jazzman
0 Lowbrow XLR pipes
Last Post: stalkie
0 Need to part with my '59
Last Post: jazzman
0 Fuel Pump Problems
Last Post: Lowe175
0 Highest mileage logged on IH engine?
Thank you very much for the write-up!
I'll add these in the Sportsterpedia.
They look good.
How much time did you spend installing them?
Rollbar's Avatar
Rollbar Rollbar is offline
Sportster/Buell Year: 1990
Rollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud ofRollbar has much to be proud of
Default 90XLH Hugger Forward Control Help/Install Questions.
Never having done this, it took me about 3-3.5 hours with test fit/ removal then the loctite and reinstall etc.
If I knew what I know now (info in the post), it should only take me about 2hours do the same removal/install on a ‘90 model etc.
Note: the instructions were kind of blurry and I just worked off the last page where it showed what number # bolt when where.
Once I figured that all out it went ok.
Same here.
I fumbled around with the OEM instructions only to find it was easier to just wing it with the included diagram.
Got em up Rollbar.
Thank you again.
http://sportsterpedia.com/doku.php/t...forwards_56129
Rollbar's Avatar
Got em up Rollbar.
Thank you again.
Awesome. Thanks again.
Bruce's Avatar
Bruce Bruce is offline
Old Fart M/C Club
Sportster/Buell Model: 883/NRHS 1250 custom
Bruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant futureBruce has a brilliant future
Nice job, they look great. By the looks of those oil lines you might want to change them, look like the are cracking and could start leaking. Ride safe!
Ride safe!
Member of "The Cell #2"
Rollbar's Avatar
Yes I agree. I should
Have done that. I’ll see if I can find some pretty easy to get a strap wrench and remove the brake arm off the frame support.
