0 Riding in The Heat!
0 What Petcock
0 Efi and carbs
Last Post: motorend
0 Mandatory Motorcycle Inspections
0 Rear master cyclinder bore size
Last Post: Truckedup
0 head and cylinder painting
Last Post: xlhshawn
0 Bike lost power,back fired and stalled
Last Post: zack74
Last Post: xena
0 7 Dead and more wounded
Last Post: seajay
0 Primary/gearbox chirp
Last Post: Jesus Jon
Last Post: Knuckles
0 When Were You Born?
0 Robbie's uncomfortable seat theory
Last Post: jazzman
0 Lowbrow XLR pipes
Last Post: stalkie
0 Need to part with my '59
Last Post: jazzman
0 Fuel Pump Problems
Last Post: Lowe175
0 Highest mileage logged on IH engine?
  #31
doodah man's Avatar
The above pic of the carb you received, it looks like the top of the enrichener plunger is bent.
Do you not have the manifold that connects the carb to the heads? You’ll need that no matter what carb you want to run. This piece...
https://www.ebay.com/itm/Ironhead-In...YAAOSwddVcsQbb
For the mikuni, yes, it’s a spigot mount. The “spigot” you want is a khs-004. I got mine on amazon.
https://www.amazon.com/Mikuni-khs-00.../dp/B00E0ST87E
Before you pull the trigger on the mikuni, you need to know that there are not many air filter set ups to choose from for them. K&N makes one that is a direct mount, but the best option (when you can find one) is a branch flowmetrics backing plate with the original oval air cleaner cover. It’s basically a hot rod piece that was designed by Jerry branch for this specific carb that he was also credited with setting up for sportsters. Check ebay, they show up from time to time. You’ll also want a custom throttle cable from Barnett.
http://xlforum.net/forums/showpost.p...6&postcount=18
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Year: 79
Yeah I have the manifold..need a spacer n yes I'm returning this carb..dont like the bent piece n it's a little bigger than mine...will do on pulling the trigger on that vm38
mickey t's Avatar
Yes I have...my enricher is bent..returning this carb...gonna look at some options
mickey t's Avatar
Originally Posted by sleighcrane View Post
Where doesn't it fit you mean that it won't bolt up to manifold?
It bolts up..just need a spacer to give me some room from manifold to throttle ...rubs when ya twist it
GA_Ironhead GA_Ironhead is online now
I'd be trying to bolt up that Mikuni... Project done for this season and many more.
Merely dying will not get your name removed from the enemies list!
mickey t's Avatar
I'm leaning to that but also there's an air filter issue w that...as far as getting one, so I'm not sure what to do at this point...
Lots of talk here on that carb: https://www.google.com/search?source....0.bNfauBqw1Y8
mickey t's Avatar
Nice..thank you
