0 Too HOT to ride?
Last Post: Bigshankhank
0 In case you have not seen Harley-Davidson's New Business Plan-
Last Post: TUCCI
2 My 1275 Hammer Conversion..
0 su carb question
0 Checking slow jet is correct size
Last Post: Billy1200
Last Post: Traxx
0 C.O.B.B. CBD oil
Last Post: TUCCI
Last Post: SLW210
0 new to me 883
Last Post: robbie202
0 New member
Last Post: spamer80
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
0 Best Street/track Camshaft for boost, help??? :)
Last Post: Jens L
0 Frame bracket
Last Post: Bwf347
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Headlight help please
Last Post: PetesPonies
Last Post: TUCCI
0 tire changer
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
0 Why cafe a sportster?
Last Post: TUCCI
0 New to the Chopper Lyfe
0 Anyone put a mechanical speedo drive on the rear wheel?
Last Post: xl883lo
0 Wtb--1967--1972 xlh
Last Post: Doc308
fhilliard (79), paulmo (75), Beloved (49), Mr. Cro (49), Chopper Duke (41), Danny3nose (39)
adjustment, ape hanger, cable, clutch
Old 11th March 2010
CNord09's Avatar
CNord09 CNord09 is offline
CNord09 is an unknown quantity at this point
Cool new clutch cable?
what is a sure fire way to find out my clutch cable is tight enuf before starting the bike? just replaced due to 12" apes.. i want to know its loose enuf before dropping it into gear.. just loosen all the way and go from there? any ideas? this forum has helped with so many things.. its on and im shutting down for tonight and will be adjusting a little tomorrow.
its a 2007, should i have any problems changing throttle cables?
-air cover off and pretty much just tearing into it from then.. any info on that would be greatly apreiciated..
i have a strong automotive background but bikes are a little diffrent so im just kinda goin with the flow and searchin this site as much as possible. thanks everyone for all the info.
wen i hear music like this, it makes me wanna peel out!
black '07 883, mini apes, red grips, vance and hines shortshots, speedo relocation, wire tuck, coil relocation.
Old 11th March 2010
Kwest187's Avatar
Kwest187 Kwest187 is offline
Sportster/Buell Model: 883/1200 standard XL
Sportster/Buell Year: MUTT
Kwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really niceKwest187 is just really nice
Does it feel snappy?
If you have a lift-put it up on that...secure it!
Start bike, pull clutch, shift into 1st...with clutch pulled...how much resistance is on the rear tire...
Once you get it close...it comes to personal preference-do you like a tight clutch or once with a little slip-
The horizon will never come into focus-but that doesn't keep me from trying.
Old 11th March 2010
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
You need some free play at the lever. You need about an 1/8" gap between the base of the lever and the housing.
Stuff: YES
Old 11th March 2010
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
+1
This is how the manual tells you to do it. 1/16th - 1/8th of an inch gap between ferrule and clutch lever bracket.
Adjustment
1. Slide rubber boot off cable adjuster mechanism. Loosen jam nut from cable adjuster. Turn adjuster until there is a large amount of free play at hand lever.
2. Remove clutch inspection cover from the primary cover.
3. Slide spring with attached hex lockplate from flats of adjusting screw.
4. Turn clutch adjusting screw counterclockwise until resistance is felt and screw will turn no further. Turn clutch adjusting screw clockwise 1/4 turn.
5. Intall lockplate and spring on adjusting screw flats. If lockplate hex does not match up with recess in outer ramp, slightly rotate adjusting screw clockwise until matchup is achieved.
6. Install clutch inspection cover with new )-ring. Install hex xocket screws with new O-rings. Tighten screws to 40-60 in-lbs torque.
7. Turn cable adjuster until all slack in braided-wire clutch cable is eliminated. Pull clutch cable ferrule away from clutch lever bracket to check free play. Turn cable adjuster as necessary to obtain 1/16th - 1/8th in. free play between end of cable ferrule and clutch lever bracket.
8. Tighten jam nut against cable adjuster.
9. Slide boot over cable adjuster mechanism.
As you can see it's better to have the service manual.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 11th March 2010
groverat's Avatar
groverat groverat is offline
groverat has disabled reputation
this thread has step by step instructions and pictures of everything
http://xlforum.net/forums/s...ad.php?t=49376
Old 25th April 2010
ironhead7777 ironhead7777 is offline
Sportster/Buell Model: xl
ironhead7777 is an unknown quantity at this point
hi
my 77 sportster has a wide road king bars, I just got a new clutch cable but seems to be shorter, does not reach the ramp lever hook inside primary or am i installing it wrong??
what size should i get?
cable is 4 sportster 77-81
No ticket, No laundry! Jack Nicholson (the departed)
Old 25th April 2010
flathead45's Avatar
flathead45 flathead45 is offline
Location: beaver dam wi. 10,000dam beavers can't be wrong
Sportster/Buell Model: FXRS-SP
Sportster/Buell Year: 86
Other Motorcycle Model: wla flathead45
Other Motorcycle Year: 1945
flathead45 has a brilliant futureflathead45 has a brilliant futureflathead45 has a brilliant futureflathead45 has a brilliant futureflathead45 has a brilliant futureflathead45 has a brilliant futureflathead45 has a brilliant futureflathead45 has a brilliant futureflathead45 has a brilliant futureflathead45 has a brilliant futureflathead45 has a brilliant future
with the engine off drop it in gear pull in the clutch and push the bike.....
does it roll... clutch is released.
does not roll... clutch is tight.
I still believe that overhead valves are a passing fad
"lord of the Night Lite"
thank god for darwin ;)
Old 27th April 2010
Mayorofrenton's Avatar
Mayorofrenton Mayorofrenton is offline
Sportster/Buell Model: 1200 CXL
Mayorofrenton is an unknown quantity at this point
I have 18" apes with jockey shift and am converting it back to standard shift....what size clutch cable do I need? I've heard +12 but that seens a little long? +10? Please help me out so I can get this done!!
