0 What engine oil do you use?
0 Front brake calliper strange noise...
Last Post: orvitarius
0 Frame bracket
0 Best Tuner options?
0 Fuel tank urns
Last Post: ezmerf
0 Happy Birthday Mrs. Folkie.
0 Hi from Barcelona!
0 top end noise
Last Post: jacsul
0 How tricky is it to replace dipstick trim from oil tank?
6 SPORTY BOBBER PICTURES
Last Post: Bryan83taco
0 Poll: Hwy Pegs: fwd mount or crash bar mount?
Last Post: oupa
0 su carb question
Last Post: Serious Blac
0 Buell special
0 how do eat an elephant,,
Last Post: cazz1000
0 Clutch lever pull effort
Last Post: Centennial Sportster
0 Psychedelic '70s SPortster Chopper Pictures
0 Too HOT to ride?
Last Post: PetesPonies
Last Post: burely
0 Another clutch Question
Last Post: wrkdWS6
0 CV Carb - Transfer Ports
Old 4 Weeks Ago
Don't forget German bearings and I have run some very good bearings that were made in Brazil.
Good materials, good heat treat, holding tolerance. These are that attributes that are most desireable. The bearings have already been designed long ago, all they have to do is stay in spec.
Old 4 Weeks Ago
Sportster/Buell Year: 1969
RicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of lightRicThompson is a glorious beacon of light
I ordered left side crank bearings from JP cycles and they are V Twin made in Taiwan. Of course picture on internet was Timken.
Fortunately they have a good return policy. I don't think I'm keeping it.
Old 4 Weeks Ago
billeuze's Avatar
billeuze billeuze is offline
Sportster/Buell Year: 80s
Other Motorcycle Year: 1983
billeuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to allbilleuze is a name known to all
Yeh, safest bet is only order from your local bearing supplier, then you know you are getting Koyo (or Sonnax or NTN, or whatever you actually order from them). I think even ordering through the HD dealership is a crap shoot, the only guarantee is that you pay 3 times what the bearing is worth.
Old 4 Weeks Ago
An HD stealership will just order from one of the big three distributors, almost all of the ironhead parts are discontinued from HD. Best to go through a bearing house. If you use eBay or Amazon beware of counterfiets and re-sellers that have no inventory..
VTwin has a horrible return policy. They will give you store credit or send another crappy part. Some items are best not ordered from VT. In many cases a used OEM part is a better choice
Old 4 Weeks Ago
nibroc nibroc is offline
Sportster/Buell Model: 68XLCH59XLCH98FLHTC99FLST
Sportster/Buell Year: 59XL
Sportster/Buell Model #2: 68XLCH
Other Motorcycle Model: 98FLHTC
Other Motorcycle Year: 99FL
nibroc is a jewel in the roughnibroc is a jewel in the roughnibroc is a jewel in the roughnibroc is a jewel in the roughnibroc is a jewel in the roughnibroc is a jewel in the roughnibroc is a jewel in the roughnibroc is a jewel in the roughnibroc is a jewel in the roughnibroc is a jewel in the roughnibroc is a jewel in the rough
sometimes more than 5 times higher.....
Old 4 Weeks Ago
Well that ate at me long enough. I'm returning the product to JP cycles. I ordered another one from Dennis Kirk, clearly stated in add "made in the USA".
Old 3 Weeks Ago
So I have received my Dennis Kirk order. Bearing is packaged different than the one received from JP Cycles. That and the $30 more this bearing cost is the only perceivable difference I can see. Probably both had the same manufacturer.
Old 3 Weeks Ago
at some point you'll want to start posting pictures here.if you want to show us what you received I can post a picture of a real Timken assembly.
Old 3 Weeks Ago
A name brand bearing will usually have the Mfgrs name on it and the number.
A no name bearing is just that....
