Last Post: robbie202
Last Post: ZCarFan
Last Post: SLW210
0 new to me 883
0 C.O.B.B. CBD oil
0 New member
2 My 1275 Hammer Conversion..
0 su carb question
Last Post: spamer80
Last Post: Billy1200
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
0 Best Street/track Camshaft for boost, help??? :)
Last Post: Jens L
0 Frame bracket
Last Post: Bwf347
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Headlight help please
Last Post: PetesPonies
Last Post: TUCCI
0 tire changer
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
0 Why cafe a sportster?
Last Post: TUCCI
0 New to the Chopper Lyfe
Last Post: Bigshankhank
0 Anyone put a mechanical speedo drive on the rear wheel?
Last Post: xl883lo
0 Wtb--1967--1972 xlh
Last Post: Doc308
0 Getting ready to try firing it up after a year long rebuid
Last Post: nychopper
fhilliard (79), paulmo (75), Beloved (49), Mr. Cro (49), Chopper Duke (41), Danny3nose (39)
instruments, nightster, tachometer
Old 17th April 2010
XLFREAK XLFREAK is offline
XLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this point
Default HD Tachometer on Nightster?
HD offers the kit for a speedo and tachometer for the 883 Sportsters. I found an older thread about this but no real answer was found. Is this compatable with the Nightster? Is the redline different for the 1200 vs the 883?
Old 17th April 2010
meteor545 meteor545 is offline
meteor545 is on a distinguished roadmeteor545 is on a distinguished roadmeteor545 is on a distinguished roadmeteor545 is on a distinguished road
a-hole answer: nightsters and sportsters are completly different wont fit.
real answer. if it isn't listed for a nightster specificaly than it probably won't be a direct bolt on. the electrical will work. i looked in the 2009 accessory cat and the tach kit i saw mounted a full size tach beside the spedo. that one could be adapted by changing your top clamp to one like pn 56115-95 (stock black upper bar clamp for a 883r) and maybe a few other small parts.
Old 17th April 2010
Pork Chop's Avatar
Pork Chop Pork Chop is offline
Sportster/Buell Model: XL883L chopped & dropped
Other Motorcycle Model: 1600 cc Volcan Classic
Other Motorcycle Year: 05
Pork Chop is a name known to allPork Chop is a name known to allPork Chop is a name known to allPork Chop is a name known to allPork Chop is a name known to allPork Chop is a name known to allPork Chop is a name known to allPork Chop is a name known to allPork Chop is a name known to allPork Chop is a name known to allPork Chop is a name known to all
HUH!
Ride Safe Eli !
Bought and paid for!
Chop, Drop, and Roll
Tankslapper of the Heavy Horses MC
Old 17th April 2010
ya the hd tach kit is listed for xl883 and xl883l. those motorcycles feature a spedo bracket that can be removed from the top clamp. the hd kit supplies all the parts nessisary to convert those bikes to the speedo/tach setup as stock on the 1200r.
it would not bolt up to a nightster or an iron or a 1200l or a 1200c because those motorcycles feature top clamps with intigrated spedo mounts.
btw porky: double post dumbass
Old 17th April 2010
Pork Chop's Avatar
REALLY? Your very observant!
Ride Hard!
= Chop =
Old 17th April 2010
yes, I am.
Old 17th April 2010
chickenhawk's Avatar
chickenhawk chickenhawk is offline
Sportster/Buell Model: XL883R
chickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura aboutchickenhawk has a spectacular aura about
You can always get the Microtach+ from Speedway Instruments. Works excellent. There are a ton of threads on it and have yet to see a person not happy that they bought it. It's a lot cheaper than buying the tach and mount from HD and you can keep the clean look of the single guage if that's what you prefer.
Old 17th April 2010
psychobooe's Avatar
psychobooe psychobooe is offline
psychobooe is an unknown quantity at this point
In order to make the H-D tach kit work on a Nightster, you would have to buy a plain handlebar clamp like the ones that come on the base 883's. Then you could use the double gauge bracket. It's the same setup that used to come on the 1200R's.
I have another suggestion for you though, Dakota Digital. I just bought their plug-and-play tachometer/speedometer combo and it's awesome. The website has all the information. For the record, I think it's totally worth the money.
http://www.dakotadigital.com/index.c...rod/prd684.htm
Old 17th April 2010
DonnyG's Avatar
DonnyG DonnyG is offline
DonnyG will become famous soon enoughDonnyG will become famous soon enoughDonnyG will become famous soon enoughDonnyG will become famous soon enoughDonnyG will become famous soon enoughDonnyG will become famous soon enoughDonnyG will become famous soon enough
The 1200S has a tach speedo combo as well, probably can't get it though, I always run into the problem of they don't make it anymore, or it won't work on the S model.
"Bad artists copy. Good artists steal."
– Pablo Picasso
Old 17th April 2010
seraphan6's Avatar
seraphan6 seraphan6 is offline
seraphan6 is a jewel in the roughseraphan6 is a jewel in the roughseraphan6 is a jewel in the roughseraphan6 is a jewel in the roughseraphan6 is a jewel in the roughseraphan6 is a jewel in the roughseraphan6 is a jewel in the roughseraphan6 is a jewel in the roughseraphan6 is a jewel in the roughseraphan6 is a jewel in the roughseraphan6 is a jewel in the rough
That has got to be the baddest gauge I've seen. I'm down for that, when it comes out.
