Last Post: robbie202
Last Post: ZCarFan
Last Post: SLW210
0 new to me 883
0 C.O.B.B. CBD oil
0 New member
2 My 1275 Hammer Conversion..
0 su carb question
Last Post: spamer80
Last Post: Billy1200
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
0 Best Street/track Camshaft for boost, help??? :)
Last Post: Jens L
0 Frame bracket
Last Post: Bwf347
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Headlight help please
Last Post: PetesPonies
Last Post: TUCCI
0 tire changer
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
0 Why cafe a sportster?
Last Post: TUCCI
0 New to the Chopper Lyfe
Last Post: Bigshankhank
0 Anyone put a mechanical speedo drive on the rear wheel?
Last Post: xl883lo
0 Wtb--1967--1972 xlh
Last Post: Doc308
0 Getting ready to try firing it up after a year long rebuid
Last Post: nychopper
fhilliard (79), paulmo (75), Beloved (49), Mr. Cro (49), Chopper Duke (41), Danny3nose (39)
instruments, nightster, tachometer
Old 8th May 2010
funnythebunny's Avatar
Senior Bike Builder
Sportster/Buell Model: XL883L Superlow
Sportster/Buell Model #2: FLHTKL Limited Low
Sportster/Buell Year #2: 2015
Other Motorcycle Model: FLSTN Softail Deluxe
Other Motorcycle Year: 2011
It's do-able!
Old 22nd July 2010
XLFREAK XLFREAK is offline
XLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this point
I posted pics on the Lets See Your Nightster thread. Works really well. No visual problems both daytime or nighttime. Also has a digital tach, cylinder head temp, and more. Worth the money. Dakota Digital makes a good product. Construction is great.
Old 10th March 2011
jedster jedster is offline
Sportster/Buell Model: xl1200n
jedster is an unknown quantity at this point
i put an earlier double guage mount and earlier tach on my 2008 nightster that matches nice,lights fit perfect, just need the tach signal pin number from control unit,looking now do u know?
Old 11th March 2011
Senior Bike Builder
I dont know what you mean by older model, but on a 2004 model, the tach signal is actually a databus signal; pin #2 from the back of the speedo colored light green with a violet stripe. Also on the same plug is your main power (brn/gry), accesory (or/wht), ignition (or) and ground (blk) at pin #7
Old 11th March 2011
thank you so much, ill give thata shot now and let you know how that works, i been a porsche and otherauto and trucks mech for over 20 yrs so if ya need any help please ask...
Old 11th March 2011
Senior Bike Builder
Welcome aboard, BTW... You should introduce yourself (no pun intended) in the threads dedicated to new members...
Old 11th March 2011
Unbalanced's Avatar
Unbalanced Unbalanced is offline
Unbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really niceUnbalanced is just really nice
Been thinking about this mod, but the bracket would be mounting to the eyebrow mount holes, which are now empty since I converted to a 7" sidemount headlight. If I can't get the cost down below the $280 or whatever HD charges for the kit though I may end up with a microtach.
Of course I got this idea about three weeks after retrofitting a bar clamp/speedo bracket from the 48 onto mine...so I'm already $100 into that.
2008 XL1200N Olive/black
Old 22nd May 2012
beanerblank's Avatar
beanerblank beanerblank is offline
Sportster/Buell Model: iron 1200
beanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura aboutbeanerblank has a spectacular aura about
So I know what numbers I need to put the pins in, but how is the connector laid out? IE what hole in the connector corresponds to the pin I need to insert? I have been piecing together my own tach parts because the dealership is ridiculous.
Old 25th May 2012
Wired up the tach 09 Iron like the
Pin 1 OR-ignition
Pin 2 LGN/V -serial data
Pin 6 O/W-Accessory
Pin 7 BK-ground
Now I have Bus er on the speedo. It still starts up, but tach isn't working.....any ideas?
Old 26th May 2012
So it appears you also need a battery feed as well. Accessory will not work. Pin 5 needs the brown/gray wire.
Why does the 09 manual have 6 different wiring diagrams for the instruments?
