Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Recall Information > 2000's Buell Recalls
0 Too HOT to ride?
Last Post: Bigshankhank
Last Post: TUCCI
2 My 1275 Hammer Conversion..
0 su carb question
Last Post: Billy1200
Last Post: Traxx
0 C.O.B.B. CBD oil
Last Post: TUCCI
Last Post: SLW210
0 new to me 883
Last Post: robbie202
0 New member
Last Post: spamer80
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
0 Best Street/track Camshaft for boost, help??? :)
Last Post: Jens L
0 Frame bracket
Last Post: Bwf347
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Headlight help please
Last Post: PetesPonies
Last Post: TUCCI
0 tire changer
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
0 Why cafe a sportster?
Last Post: TUCCI
0 New to the Chopper Lyfe
0 Anyone put a mechanical speedo drive on the rear wheel?
Last Post: xl883lo
0 Wtb--1967--1972 xlh
Last Post: Doc308
fhilliard (79), paulmo (75), Beloved (49), Mr. Cro (49), Chopper Duke (41), Danny3nose (39)
Old 24th October 2007
bplinson's Avatar
bplinson bplinson is offline
The XL Forum Host
Sportster/Buell Model: 883>1250 Stage 2
Other Motorcycle Model: Road Glide
Other Motorcycle Year: 2011
bplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond repute
Default 2004 Buell Recall - BLAST - FUEL SYSTEM
Make : BUELL
Model : BLAST
Year : 2004
Manufacturer : BUELL MOTORCYCLE CO.
NHTSA CAMPAIGN ID Number : 04V365000
Mfr's Report Date : JUL 23, 2004
Component: FUEL SYSTEM, GASOLINE
Potential Number Of Units Affected : 656
Summary:
ON CERTAIN MOTORCYCLES, THE VALVE WHICH WAS DESIGNED TO ALLOW AIR TO REPLACE FUEL IN THE TANK DURING OPERATION COULD MALFUNCTION THEREBY STARVING THE ENGINE FOR FUEL.
Consequence:
THIS SITUATION COULD CAUSE THE VEHICLE TO SHUT DOWN WITHOUT WARNING, WHICH COULD LEAD TO A CRASH, CAUSING THE POSSIBILITY OF DEATH OR INJURY.
Remedy:
BUELL WILL REPLACE THE VENT VALVE. THE RECALL BEGAN ON AUGUST 27, 2004. OWNERS SHOULD CONTACT BUELL AT 414-343-8400.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Recall Documents
RCQPR-04V365-9887.PDF Quarterly Performance Report
RCQPR-04V365-7615.PDF Quarterly Performance Report
RCMR-04V365-7652.PDF Manufacturer Reply
RCRN-04V365-6918.PDF Renotification Notice
RCNOC-04V365-3398.PDF NHTSA Originated Correspondence
RCQPR-04V365-6055.PDF Quarterly Performance Report
RCQPR-04V365-8396.PDF Quarterly Performance Report
RCQPR-04V365-3780.PDF Quarterly Performance Report
RCONL-04V365-2952.PDF Owner Notification Letter(Part 577)
RCRIT-04V365-5702.PDF Remedy Instructions and TSB
RCQPR-04V365-6798.pdf Quarterly Performance Report
RCFK-04V365-8664.pdf Fax Acknowledgement
RCDNN-04V365-3898.pdf Defect and Noncompliance Notice(Part 573)
AMA #961454
