0 2 into 1 exhaust build
Last Post: cazz1000
Last Post: Trailhawk750
0 900 dual carb front head
0 Project Strociek
Last Post: Yakcm2
0 WTF Happened
Last Post: Yakcm2
Last Post: Steamboat_Willy
0 Buell lightning
Last Post: Airbozo
Last Post: Yakcm2
0 08 Nightster No Start
0 Have you ever bought Viagra or any other drug....
Last Post: jammantoo
Last Post: LLOYD883
0 Nightster suspension upgrade (RK). Who has em?
Last Post: SportyHD
5 Do you feel you pay too much for Motorcycle Insurance?
Last Post: Eric Von Zipper
0 Sportster in custom softail frame
0 compression problems
Last Post: Eddie Lives On
0 Khk flywheels in my ironhead....timing
0 wanted rim info
Last Post: curiousgeorge
Last Post: RAIDER0372
0 Air Filter Soaks With Gas
Last Post: Hopalong48
0 A Day in the Life...
0 Should I buy a Sportster??
Last Post: geekonabike
Old 15th June 2018
DéDé's Avatar
DéDé DéDé is offline
Sportster/Buell Model: XL 883
Sportster/Buell Year: 04
Other Motorcycle Model: Street Bob
Other Motorcycle Year: 08
DéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really nice
Default 07 heads on 04 rubbermount
Hi,
my front head starts to loose compression, tested by an official HD dealer today
front 7,0 bar
rear 9,5 bar
bike has 30.000 mls
bike runs not bad, but at idle it seems little bit like a steam hammer, because rear is fine, front bad
before I do a complete head job front and rear, it´ll be better ta take some used take off parts of a nearly new 1200 converted sportsers, which is very cheap
my question is, what do I have to do, to use 07 and later heads on my bike with the carburetor. As far as I know the manifold flanges changed - what do I need?
thx
Old 15th June 2018
shanneba shanneba is offline
http://www.hammerperf.com/xltopend.shtml#heads
Be aware that there was a significant change beginning in 2007 when the factory went to fuel injection on the Sportsters. 2007 and newer XL heads have their manifold mating surface milled down about .062" versus the carburetor heads, and also they have the manifold flange bolts moved apart to accommodate the larger EFI throttle body, with wider manifold flanges to match.
The 2007-up heads however can be used with a carburetor by using a special wider intake manifold available from HAMMER PERFORMANCE.
http://www.hammerperf.com/xlfuelsyst...illetmanifolds
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 16th June 2018
DéDé's Avatar
thank you very much
Old 16th June 2018
DéDé's Avatar
ok, so I need only the newer flanges 2x 27327-07A an th Hammer Performance Manifold?
....an 07 cylinders and pistons will fit also on my rubbermount?
thx
Old 1st July 2018
DéDé's Avatar
Now I ordered this manifold from Hammer Performance. Perfect communication with Aaron
Old 12th July 2018
DéDé's Avatar
manifold an flanges came today - perfect
now I´ve everything to assemble my 2010 Iron pistons, cylinders and heads on my 2004 rubbermount. There is only one question. Seems like these o-rings on cylinder dowels disappeared in 2008. Do I just need the newer head gaskets 16664-86D to assemble ?
thx
Old 13th July 2018
rocketmangb's Avatar
Should just need the gaskets.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 13th July 2018
DéDé's Avatar
ok that´s what I thought, thx
Old 8th October 2018
DéDé's Avatar
ok, here some pics
20180616_061707 by DéDé1963, auf Flickr
DéDé's Avatar
as you can see, my front cylinder is loosing copression, i knew this when I bought this bike, so I got it real cheap.
Bike was in very good condition but runs like crap, no services done the last years and a bad intake leak.
