0 In a crash: Lucky to be alive
0 Misfire 02 883
Last Post: Thegen58
0 Why I don't have a HID Headlight Poll
0 answer with a question game
Last Post: 72 Ironhead XLH
0 What engine oil do you use?
Last Post: Clevspeed
0 headlight upgrade
Last Post: Dcoff
5 Harley T-Shirts
0 New handlebar wiring harness 81XLH?
0 Head gasket leak.
Last Post: lucifer_mr2
0 (Do) (Are) Loud Exhausts__________.
Last Post: Eddieblz
0 Ever been pulled over?
Last Post: Sprtstr1200s
0 Regulator battery draw
6 Calling all musicians
Last Post: Eddieblz
0 Ran out of gas.
14 Post your Bike in a Cemetary Pic
0 Safe Max Rev Limit stock engine Roadster 2017
Last Post: eduardox23
0 '04+ Starting Issues, Do You Have Them? - Poll
0 A Day in the Life...
0 Starter problem
WinXP (68), Maggie (62), grancan1 (54), SRKASM (48), metalmessiah, o113attitude (44), stinkynate (36), wingman_214 (35)
Old 13th October 2018
harley506d's Avatar
Sportster/Buell Model: 1200c
Love it! Classy job.
Old 15th October 2018
DéDé's Avatar
DéDé DéDé is offline
Sportster/Buell Model: XL 883
Sportster/Buell Year: 04
Other Motorcycle Model: Street Bob
Other Motorcycle Year: 08
DéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really niceDéDé is just really nice
just took of cam cover, see what I found.....
20181015_163714 by DéDé1963, auf Flickr
20181015_171813 by DéDé1963, auf Flickr
Zwischenablage01a by DéDé1963, auf Flickr
DéDé's Avatar
no surprise, I have a wrong cam timing, but it´s different to what I´ve expected
DéDé's Avatar
ok, problem solved, cam one and three were wrong - one tooth , and when three is wrong number four ist automatically wrong too
Zwischenablage04 by DéDé1963, auf Flickr
DéDé's Avatar
20181015_195830 by DéDé1963, auf Flickr
20181015_195815 by DéDé1963, auf Flickr
DéDé's Avatar
Oil pump gear looks like new
20181015_201109 by DéDé1963, auf Flickr
now the question...
Do you think it is possible that this timing issue is factory made?
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Maybe I'm missing something, but I don't see anything wrong with the cam marks.
Always check them with the pinion mark pointing straight toward the middle of the #2 cam.
However, I do see wear on your oil pump drive gear. Look more closely.
Also, the nature of the wear on that gear is such that it'll look absolutely perfect in one area, and then 180 degrees from that spot you'll see it badly worn. So look all the way around.
But even in your picture, I can see the tooth starting to sharpen.
Click Here to Contact Me
DéDé's Avatar
ok I looked all around the oil pump gear, some sharpening yes, but overall good
timing
before
after new setting
hbsporty's Avatar
hbsporty hbsporty is offline
Sportster/Buell Model: 883c>1250cc
Other Motorcycle Model: 2002 FLH Standard
hbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud ofhbsporty has much to be proud of
Paint looks good
Old 16th October 2018
DéDé's Avatar
thx
ok I´m ready with assembly, just came back from a test ride, problem is solved, runs perfect, on idle too, strong on both cylinders, like it should be
20181016_210108 by DéDé1963, auf Flickr
