Last Post: oupa
0 Front cylinder noise
0 Modified heads
Last Post: Medyo Bastos
0 Spectro STL 75W140
Last Post: VaFish
0 Buell lightning
Last Post: Stickr
5 03 XlH1200 Best top end commination.
Last Post: Saint666
0 Tried starting the bike this morning, batter charged, but bike wont turnover?
0 79 Tranny
Last Post: sltm1
0 Bendix / Zenith questions
Last Post: DirtyHarry68
Last Post: Bone
0 Lacing a 21 inch wheel to a 19 inch hub
Last Post: 72 Ironhead XLH
0 1981 ironhead xlh PROJECT
Last Post: Wilkinson949
0 900 dual carb front head
Last Post: thefrenchowl
0 Hi from NY state
0 Runs rough on highway.
0 Hi from Buffalo
5 '77 ironhead fork neck cup conversion internal steering stop
Last Post: Slojoe55
6 SPORTY BOBBER PICTURES
Last Post: Phappus
0 08 Nightster No Start
Last Post: andyb
0 hi from anchorage AK
Last Post: Phappus
Wild One, Bugs (66), Blazer (63), OnDVirg (63), Buggyboy (60), TheChimp (45)
Old 22nd August 2018
bimbo's Avatar
bimbo bimbo is offline
Sportster/Buell Model: 883 x 1200
bimbo has a brilliant futurebimbo has a brilliant futurebimbo has a brilliant futurebimbo has a brilliant futurebimbo has a brilliant futurebimbo has a brilliant futurebimbo has a brilliant futurebimbo has a brilliant futurebimbo has a brilliant futurebimbo has a brilliant futurebimbo has a brilliant future
Default Brembo brakes - a little hand holding please
2005 standard 883 (converted to 1200)
Hi
After reading up a few of the brake replacement threads I have gone and ordered a pair of calipers ( part numbers 43027-08 44023-08 ) and am now trying to find the correct EBC Floating Discs.
I'm after a more experienced player in this market to hold my hand and confirm that I got the right bits for my 2005 rubber mount.
bimbo's Avatar
Just had a (very quick) reply from EBC
Hi John,
Thank you for your email.
The FSD004 fits the 883. I have found a 300mm disc that is the same fitting patterns. It is the MD530.
Kind regards
Gareth Preston
Technical Advisor Motorcycle
01604 583344
ReddTigger's Avatar
md250 would be for the 2008 and newer touring bikes and that is what uses the brembo's
States I've Ridden in
71.3 hp 70.8 tq
bimbo's Avatar
Hi Red, I can't find MD250 anyplace?
ReddTigger's Avatar
Where r u located ? this was on jpcycles web site ..
ok might have been dyslexia.
try md 520
https://www.jpcycles.com/product/210...el-brake-rotor
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
I have no idea which EBC rotor will or won't work. The one thing I think worth mentioning is that many of OEM rotors for the touring bikes don't have the countersunk mounting holes, leading to clearance issues on the Sporty narrow glide front ends. I have no idea which of the EBC rotors may/may not have the countersunk mounting holes.
Do you know if these MD520's are countersunk mounting holes?
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
bimbo's Avatar
try md 520
In the UK, EBC is local stuff for me. they do a full range of Harley Discs
bimbo's Avatar
From the photos, both the MD520 and 530 have recesses for the bolt heads.
Yeah, I saw that but I never trust marketing photos.
Old 23rd August 2018
rocketmangb's Avatar
HMM
I bought a used pair of calipers I think were Night Rod
Also HD floating rotors for a Sportster
Havent really looked at all of it.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
