0 XLH 883 1987. Please advise. (Jetting And Air Filter)
Last Post: xlh883-1987
0 vibration problem solved - CHECK YOUR FRONT ENGINE MOUNT BOLT!!
Last Post: Bruce
0 My 1250 to 1275 build
Last Post: Bruce
0 Locked up rear wheel
Last Post: Darkseacret
0 25 April
0 Happy Birthday Decman!!!
Last Post: sltm1
0 Trans sprocket spacer is stuck
Last Post: xleddie
6 Calling all musicians
0 Been Sitting For 5-10 years; Starts, But Dies
Last Post: Feskerlars
Last Post: borada75xlch
7 Saying hello and getting acquainted!
Last Post: Flyboy25
0 My '08 short chop
Last Post: Dudepants
0 2004 rear mast cylinder
0 left him stranded
Last Post: davixlrtt
0 THE Hockey Thread
Last Post: Airbozo
6 73 Sportster Starts, Runs Fine, Dies
Last Post: Huginn
0 Evo sporty straw diagonal measurement... 883? 1200?
Last Post: ericfx1984
0 Gasket goo or not to goo
Last Post: Jollly Rogers
0 Rear rocker cover?
0 Resistor vs Copper plug wires?
0 77 xlh front end front vibration
0 Scored new to me used tins
0 BETTER Brakes for $214
0 First Startup after rebuild questions
Last Post: frogg_nutts
Durockrolly (61), xlch1973 (57), Rich_Alfredo (57), ehenry (55), 100thHugger (54), evobrian (52), jethrosurfs (47), Chris B. (43), Ebmomma (43)
View Poll Results: Does your Rubbermount use too much oil (more than 1 QT. per 1,000 miles)
04- NO 197 20.82%
04- YES 42 4.44%
05- NO 224 23.68%
05- YES 40 4.23%
06- NO 220 23.26%
06- YES 23 2.43%
07- NO 88 9.30%
07- YES 7 0.74%
08- NO 57 6.03%
08- YES 7 0.74%
09- NO 9 0.95%
09- YES 0 0%
10- NO 10 1.06%
10- YES 0 0%
11- NO 1 0.11%
11- YES 1 0.11%
12- NO 10 1.06%
12- YES 0 0%
13- NO 2 0.21%
13- YES 1 0.11%
14- NO 7 0.74%
14- YES 0 0%
Voters: 946. You may not vote on this poll
Old 22nd August 2007
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Default Rubbermount oil consumption poll
May have been one of these, but not this specific...
This is for RUBBERMOUNT OWNERS ONLY!!
I'm curious to see how widespread this problem is among our members.
The MOCO says anything up to 1 Qt. per 1000 miles is NORMAL.
We will not argue THAT point, for these purposes, let's just compare our experiences...
If yours DID, but has been fixed...VOTE YES for your year...
~Chuck
Occam's Razor...
XLF Tuning Stickies
CBAS5 CBAS5 is offline
CBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud ofCBAS5 has much to be proud of
The MOCO says 1 qt/ 1000 mi. is normal because that is the INDUSTRY STANDARD. If you asked suzuki, toyota, honda, GM or any other company than they would give you exactly the same response.
2005 XL1200C
Those who trade liberty for security have neither.
unfiguroutable's Avatar
unfiguroutable unfiguroutable is offline
Sportster/Buell Model: XL883L
unfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the roughunfiguroutable is a jewel in the rough
Default 3 quarts
3 quarts come out every oil change and three go right back in. my oil level is perfect. i run the regular interval (5k) and use rev tech 20/50 oil in my stage 1 (minus heads) 05 low
LoyaltyRB
cantolina's Avatar
Well, there were two reasons I set up this poll....
One is this statement, from another thread:
Originally Posted by bmmccandless View Post
Here's the deal, the majority, probably 90% of the rubbermount engines are having oil issues
Later, he admits he's being a bit dramatic.... ....which is fine, but I believe the number is about the polar opposite...
Secondly, I'd like to know, for my own purposes, if this is or is not limited to 04/05 bikes....
You should have specified stock/stage 1 rubbermounts. Some conversions are having oil consumption problems and that seems to be at a much larger percentage than stock oil consumption.
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
My bike uses maybe ½ quart between oil changes every 5,000 miles.
Folkie
South East England Riders
Old 23rd August 2007
cantolina's Avatar
We've already had a poll about conversions and oil usage...
Not even sure stage 1 is an issue at ALL...(Stage 1 not to be confused with converted, right?...you mention both)
Depending on the results, maybe we'll narrow some things down later...when a good number of votes are in...
For right now, I'm just interested in the overall prevalence of the problem, and more specifically with regard to years..
I don't care if its an 883 or a 1200, what's been done to it, nothing...other than a problem existing (or having existed once) and the year....
BTW...if you vote yes...PLEASE elaborate...
buckhorns's Avatar
buckhorns buckhorns is offline
Sportster/Buell Model: Electra Glide Classic
buckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura aboutbuckhorns has a spectacular aura about
Stage I on my 06 1200C, and it used a quart between the 5000 and ,7500 mile oil changes. I don't run it too hard though. WOT once in a while, and run 70-80 on interstate, run easy in the twistys. I'm not complaining. Hope I never have to.
Am I Here ?
Where Was I ? Where Are My Meds ?
Don't worry about old age...it doesn't last long.
Piggy's Avatar
Piggy Piggy is offline
Other Motorcycle Model: Dyna Street Bob
Other Motorcycle Year: 2007
Piggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enoughPiggy will become famous soon enough
05 883C
didn't use much oil at all when still an 883, used a quart every 500-600 miles after conversion to 1250.
Current bike: 07 Street Bob
V&H Short Shots, SE air cleaner, Power Commander, forward controls
Previous bike: 2005 Sporty NRHS 883/1250C conversion AKA oil guzzler R.I.P
cantolina's Avatar
Originally Posted by Piggy View Post
05 883C
Just out of curiosity, how many miles on it before the conversion?
