Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > FORUM FUNCTIONS > Sportsterpedia.com Admin
Sportsterpedia.com Admin For discussion regarding the administration of the Sportster Wiki.
0 changing rocker arm bushings
Last Post: Bone
0 Realistic performance guesstimate?
Last Post: Curbside
Last Post: Adam76
0 Ride Height Change With Shock Length Change
Last Post: Adam76
0 Hello from Tennessee
0 Poll: How Tall are You?
Last Post: geekonabike
0 joyride memories xlx ironhead
0 ******* usps
Last Post: oupa
Last Post: oupa
0 A Weekend at the Races
Last Post: oupa
0 My new buckhorn bars
Last Post: oupa
0 timing troubles!
0 Is this 1200R worth $4500?
Last Post: Bone
0 primary chain adjuster spring load..?
Last Post: 1977iron
0 WTB: S&S Super E Jets
Last Post: wrkdWS6
4 Grinding noise when revving up
Last Post: Grumpy-Biker
0 Winter Storm Warning
0 Riser Fitment Question
Last Post: Toms99tj
0 Mid or forward controls.
Last Post: 5mel42
jurneyman (77), AdO650 (63), xlsport (61), darth (58), mcsmokinp (54), stalkie (54), unleashed66 (53), 66xlch (53), lownslow (47), hrg (45)
Old 25th January 2016
Hippysmack's Avatar
Hippysmack Hippysmack is online now
Default Factory Carburetors for all Sportsters
I've added a chart in the carburetor section listing serial numbers of carbs including the bike they were originally fitted to. This is all the information I have on the subject. Check it out and if you have information that's not included, you can pm me your 1. factory carb serial no., 2. Year and model Sporty it came on, and I'll include it. especially HDI/ Swiss models. http://sportsterpedia.com/doku.php/how_to:evocarb:start
Thanks!
Hippysmack's Avatar
Shameless Bump
Old 31st January 2016
Hippysmack's Avatar
The 'Keihin carb numbers and jetting' section for years 1988-2003 is done to all the info I have at the moment. Some of the carb numbers may be HDI or Swiss but I won't know that without more info. This section does include info for US, HDI and Swiss models as well. If your bike/ carb is not listed, please send me the info and I'll include it. This info should be in your year specific parts manual if you haven't noticed it written on your factory carb.
Thanks....Oh yeah, How does it look? Would you rather the info be in these tables or simply written out? Anything I can add or correct? This is all of our project after all and if it just sux, I'd rather fix it.
Old 3rd April 2017
Hippysmack's Avatar
Updating this thread.
The carb section has been split up into the Ironhead http://sportsterpedia.com/doku.php/techtalk:ih:carb01 and Evo http://sportsterpedia.com/doku.php/techtalk:evo:carb01 sections respectively in the wiki searchable by bike model and year. The full list is still in the reference section http://sportsterpedia.com/doku.php/techtalk:ref:carb01. That list will be cut down to mainly a quick reference list searchable by carb number. The technical info on the carbs will be with their respective engine sections.
Old 3rd April 2017
Hippysmack's Avatar
I am going through the EVO section while changing the format and I have a question. 2003 parts catalog shows a carb # 27495-96A for California models 883/883Hug/ 883C and 883R. However, it does not show main jets, or anything else for 883R (Cali) in the carb section which is out of the ordinary. Can anybody tell me why? Surely the 883R was sold as a California model also. Did HD just screw up a cut and paste?
Old 3rd April 2017
Hippysmack's Avatar
Old 3rd April 2017
rocketmangb's Avatar
Heres what I have in my toolbox
27495-96A 2003 883C
27732-04 2006 1200C
27731-04 Unknown (bought used) ran fine on my '06
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 4th April 2017
Hippysmack's Avatar
27495-96A 2003 883C
27732-04 2006 1200C
According to the chart I'm working on from the parts books:
27731-04 = Domestic 1200C/R
27732-04 = Cali 1200C/R
27495-96A = Cali 883s
I'd like to hang some pics especially noting the differences in these carbs if you know them
Old 16th April 2017
mwXL 2006's Avatar
mwXL 2006 mwXL 2006 is offline
Sportster/Buell Model: xl 1200c custom
mwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to beholdmwXL 2006 is a splendid one to behold
In the carb section for the 04-06 rubber mounts, my FSM says the jets are 42/180. Dealer told me 42/165 which I found odd. carb # 27731-04 is correct. Great job on this info.
Xl 1200c custom 2006 carb.
42 CVP pilot 180 main
3 out a/f screw
V&H straightshot slip-ons
K&N Hi-Flow 587 air cleaner
Breather Bolts to air
Love to ride. Stay safe
Milt
http://sportsterpedia.com/doku.php/start Use it great info
https://postimages.org/ for your photos
Old 16th April 2017
Hippysmack's Avatar
Attachment 19972
Thanks!
180/42 was confirmed through the parts manual with the part numbers for those jets. Here is the new link to the Evo carb listings http://sportsterpedia.com/doku.php/t...portster_model
I started from 2006 and went down to 1986 using both the parts catalogs and the FSMs due to errors in one or the other books. I still need to review and so does everyone else to check for errors. I also noted along the way (although I started to give up close to the end) the descrepancies I noticed within the books and found more errors and mis-representations in the parts catalogs than I did the FSMs. Here is the link to that (although it's just at the bottom of the carb listings) http://sportsterpedia.com/doku.php/t...arts_catalog_s
I am missing a few years FSMs, 95-96-97-99-03-05-06. Other than that I am finished with the list. I have added at the top of the Evo chart, an Iron Head chart also from 1957-1985 http://sportsterpedia.com/doku.php/t...l_model_number
