0 Tachometer Suggestions
Last Post: BigMek
0 The Strociek Project
10 1983 XR 1000 Starting Issues.
Last Post: CT XR rider
Last Post: XL Ed
0 Video - Why Tire PSI Should Be Checked Often!
0 72 ih stroker advise needed
Last Post: rocketnorton
0 Ironhead engine problem?
Last Post: ZTatZAU
0 1968 ex barn dweller thread
0 Starter gaskets 74 XLH1000
0 Starting?
Last Post: Briank
Last Post: splineman
Last Post: Turbo Sporty 48
0 NOS cases
0 Video - Servicing the External Breather Catch Can
garryd (73), Chooch (70), kicker (64), Calgaich (61), skinnyboy (59), RogerB, Tonyb65 (56), sunkenloot (46), scoobs48, zman69 (40)
breather timing, sportster, sumping, xlch
Old 26th March 2021
Hippysmack's Avatar
So, you had the vent line removed and the motor running?
I assumed you either had a leak there or clear hose for testing as you mentioned with the return.
If you simply took the vent line off, you opened an area in the cam chest that is reserved for oil separation.
Which will cause puking out the vent fitting on the motor.
Hook the line back up and that problem should go away.
Old 26th March 2021
sungod's Avatar
sungod sungod is offline
Sportster/Buell Model: sportster xlch
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 73
Default 1960 xlch
Sportsters are dry sump engines so there should be no oil flowing out the vent hose.With the hose removed there will be pulsing air due to the pistons up and down strokes and no oil flow as you described. The breather tube in the front of the gearcase should remove the air. If the gearcase is filling up or pressurizing oil and coming out the vent hose the breather/oil pump is suspect.The breather screen could be partially clogged since you mention some oil/mist out of the breather tube.
Old 26th March 2021
Hi XL604,
This is probably a long shot question but it can't hurt to check. Do your 3 oil lines connect to the crankcase the same as the ones in this thread, post #1?
http://xlforum.net/forums/showthread.php?t=967253
Also, did you have this problem before the rebuild?
Old 27th March 2021
DR DICK's Avatar
DR DICK DR DICK is offline
Originally Posted by XL 604 View Post
Mine is almost like another return so much oil comes out
thats your problem.
in a nutshell:
there are two oil pumps
a supply pump (skinny gears)
and a return pump (thick gears)
that means there is more volume gettin returned back into the oil tank than is being feed into the engine by the feed pump.
but you cant return more oil than was feed in.
so some of the return volume isnt oil, its air.
so the oil tank gets all the feed oil returned plus the excess air.
that would pressurize the oil tank if it wasnt for the vent line that returns excess air back to the cam cover where it equalizes with the atmosphere through the cam cover via puke tube.
for all this to happen the open end of the vent system inside the oil tank must be in the air space above the oil level in tank.
because you say the vent line is transferring oil not air back to the camcase it seems that your oiltank plumbing is faulty.
D.D._____________________________-o&o____________________________
Old 29th March 2021
sungod's Avatar
Default 1960 xlch
After rereading all the comments I have the feeling the breather timing needs to be rechecked.The breather should start to open at 20-25 deg. atdc front cylinder. Verify this is happening.
Old 30th March 2021
randy3934's Avatar
I think the engine is sumped, then more oil added, then for unknown reason the oil tank vent line was removed and found to be the return line, oil hoses are plumbed wrong. OP hasn't said anything about oil coming from the vent tube on the generator end of the gearcase.
Old 30th March 2021
Sounds to me like lines were connected incorrectly after the rebuild/oil pump swap. Oil tank fittings identified: http://www.harleykmodel.com/technica...nks/index.html
Science doesn't care what you think.
