Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Dealers, Stealers, Indys and Parts Dealers
Dealers, Stealers, Indys and Parts Dealers Who did good by you and who did bad by you
0 gas tank paint protection
0 whats your iron head worth
Last Post: Scott
0 If you don't bring closure to your thread, then the terrorists have won
0 Winter reading........
0 THE Trainspotting Thread
5 Run/Turn/Brake light problems
5 Terminology Sticky?
0 Sign of getting old...
Last Post: Firehawk
0 12" or 14"? (Apehangers)
Last Post: Nrg2brn
Last Post: oupa
0 Mainshaft- What happened here
Last Post: moparnut360
6 Is Your SPORTSTER...
Last Post: Kbetts
Last Post: oupa
0 Frontbrake upgrade - simple and cheap - how to will follow if there's any interest
Last Post: Yakcm2
0 How much should I offer for this 48
pwssr, petefwa, skeeter883 (67), roadogette (66), khaskins (61), iriegnome (54), sportster808 (51), ironheadmax (49), matt275 (44), DJb (43), HDFirefighter (37)
Old 4th May 2017
WhiteChapelX WhiteChapelX is offline
Sportster/Buell Model: 883XL
WhiteChapelX has much to be proud ofWhiteChapelX has much to be proud ofWhiteChapelX has much to be proud ofWhiteChapelX has much to be proud ofWhiteChapelX has much to be proud ofWhiteChapelX has much to be proud ofWhiteChapelX has much to be proud ofWhiteChapelX has much to be proud ofWhiteChapelX has much to be proud ofWhiteChapelX has much to be proud ofWhiteChapelX has much to be proud of
Default m40customcycles on eBay - rip off artist
I bought a shift lever off this seller on eBay that he had advertised as a 91-05 for XL models. I should have known it wasn't going to fit, but figured I would roll the dice.
Sure enough, the damn packaging from Drag Specialties says 91-03 on it. I file a claim for it, and he declines it and keeps saying that it fits an 05 XL.
Anyway, eBay's sided with me on the matter, but the sellers a dick.
Stay away.
Old 4th May 2017
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Model #2: Xl 883n
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Just curious, did it fit?
Old 5th May 2017
Lol, hell no.
The problem is that there is an error in advertising them. Basically, 91-03 works, but the way the bolt lines up when tightening down the shift lever on the shifter shaft coming out of the primary.
The shaft is notched differently on 91-03 sportsters than on 04+ models, but I think 04-06 are the same and 07+ are different, which means the shift lever can't be tightened down unless you put a new notch in the shaft itself, and wel, I didn't want to go through that if not necessary, let alone the shifter lever would not line up correctly along the primary.
Also, the tightening bolt on 91-03 models and 04+ models are different sizes - later models are much thicker. So that adds to some of the differences.
