0 The Harroway: Sefton Warren To Powderham Castle
Last Post: mac93
0 Out of the Box Thinking
Last Post: sltm1
0 Gravydog crashed again.
0 fat man on a sportster
0 What do you think the wet weight of the Pan America will be?
0 Dead battery cells - 1997 sportster 883
0 Moto Guzzi V9 Bobber debut
0 Broke fin on head.
Last Post: lynnx
0 1960 XLCH in the UK
Last Post: lynnx
0 mode of failure
Last Post: WI Bob
0 Let's study the 77-85 oil pump, parts, and changes and when.
Last Post: sprink
6 Is Your SPORTSTER...
0 Replacement Fuel line?
0 130/90- 16 tire on rear 16x3.5 wheel or change to 140/90?
Last Post: Lupush
0 Wanted: Morris Magneto X5 magneto drive gear
Last Post: Lobster
0 New 2004+ Carb Heads
Last Post: t120r
0 New England 2018
Last Post: Boudwood
0 getting this 78 back to the way it should be.
ziggyhd1 (60), greven (58), bliynd (33)
electric franks rebuild, high voltage regulator, hight volts reading, ironhead, rickmodee
Old 25th May 2018
rickmodee rickmodee is offline
Other Motorcycle Model: fx
Other Motorcycle Year: 77
rickmodee is a jewel in the roughrickmodee is a jewel in the roughrickmodee is a jewel in the roughrickmodee is a jewel in the roughrickmodee is a jewel in the roughrickmodee is a jewel in the roughrickmodee is a jewel in the roughrickmodee is a jewel in the roughrickmodee is a jewel in the roughrickmodee is a jewel in the roughrickmodee is a jewel in the rough
cap can fail
1. open
2. short
3. change of value
each with their own effects. best to test dynamically, either replace or bring to a tv shop with a cap tester capable of dynamic test under voltage.
There’s a shop in town I’ll take it to. Check back in a few. Thanks
2000 xl,1975 xlch
Old 25th May 2018
electronic voltage regulator on a bike with no battery is not your problem.i have one on my 1960 XLCH. so do others.
