0 The Harroway: Sefton Warren To Powderham Castle
Last Post: mac93
0 Out of the Box Thinking
Last Post: sltm1
0 Gravydog crashed again.
0 fat man on a sportster
0 What do you think the wet weight of the Pan America will be?
0 Dead battery cells - 1997 sportster 883
0 Moto Guzzi V9 Bobber debut
0 Broke fin on head.
Last Post: lynnx
0 1960 XLCH in the UK
Last Post: lynnx
0 mode of failure
Last Post: WI Bob
0 Let's study the 77-85 oil pump, parts, and changes and when.
Last Post: sprink
6 Is Your SPORTSTER...
0 Replacement Fuel line?
0 130/90- 16 tire on rear 16x3.5 wheel or change to 140/90?
Last Post: Lupush
0 Wanted: Morris Magneto X5 magneto drive gear
Last Post: Lobster
0 New 2004+ Carb Heads
Last Post: t120r
0 New England 2018
Last Post: Boudwood
0 getting this 78 back to the way it should be.
ziggyhd1 (60), greven (58), bliynd (33)
Old 20th May 2018
lew265 lew265 is offline
Sportster/Buell Model: xl 883/1250
lew265 is an unknown quantity at this point
Question Am I looking for Trouble ?
Hi all. My 883/1250 with powervision,Big Sucker A/C and rush slip ons started backfiring and surging at low speeds. Code po 131. I changed the front o2 sensor and still had the problem.
Now three weeks later and frustrated I decided to throw on my old X14IED from nightrider.
Bike is running like it never ran before OMG!!! [powervison still connected]
Can I keep running this combination? what's the worst can happen
GURUS PLEASE HELP.
Thanks
Old 21st May 2018
well if you biased the o2 to read down the middle, probably forever. the ecu can only act upon data given it and if it stays locked so does the feedback. i am not sure what the x14ied is inside but the o2 can be tricked with a diode since it has a constant voltage drop of .6volt.
where you get into trouble is when you have fore and aft o2. the ecu compares the two to tell if the cat is still meowing!
Old 23rd May 2018
LUNCHBEEF's Avatar
LUNCHBEEF LUNCHBEEF is offline
Sportster/Buell Model: IRON 883
Sportster/Buell Year: 2012
LUNCHBEEF is a name known to allLUNCHBEEF is a name known to allLUNCHBEEF is a name known to allLUNCHBEEF is a name known to allLUNCHBEEF is a name known to allLUNCHBEEF is a name known to allLUNCHBEEF is a name known to allLUNCHBEEF is a name known to allLUNCHBEEF is a name known to allLUNCHBEEF is a name known to allLUNCHBEEF is a name known to all
did you flash the computer with the base tune the company gave you? - I bought my 1250 kit from nrhs and they sent me a base tune to run and then you run the auto tune program for some time to dial it in.
Old 23rd May 2018
Exactly what I did. Bike was running fine untill it stripped a base stud hole on the rear cylinder. Repaired stud with timesert and re assembled . That is where my problems started.
I did not change tune. but kept getting code PO 131 backfiring and low speed cut cut off.
Old 23rd May 2018
Your original O2 sensor was probably not bad, it was indicating the front cylinder was running lean. Did you check your intake manifold seals for leaks after your rear cylinder repair?
The X14IEDs are changing the voltage the ECU sees causing the ECU to add more fuel eliminating some of your lean condition. If you have an intake leak you will be pulling in unfiltered air into the cylinder.
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 27th May 2018
Exclamation
No intake leaks when tested,Am gonna ride her this weekend , get her nice and hot then check for leaks, maybe it will show up when the metals expand.
Old 27th May 2018
Crosshairs's Avatar
Crosshairs Crosshairs is offline
Sportster/Buell Model: Its Black and shiny
Crosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond repute
it sounds like you now have a leak at the exhaust gasket which is throwing off the 02 sensor reading
