0 Oh these college kids
Last Post: bordens
0 Yearly Allotment of Miles
0 Headwork
Last Post: Staffords
0 New guy from IL
Last Post: TamiSchall
0 Tranny oil
Last Post: Billy1200
0 73 XL 1000 Sportster - SOLENOID BYPASS
Last Post: 4th of July
Last Post: davesz1r
0 WTB: XR1200 Luggage Rack and Tailbag (OEM)
0 Chinese S&S carbs
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 1979 Ironhead Starter Washer, Bushing
Last Post: Tipofthelake
0 Highway cruise speed
Last Post: rich56
0 Why such heavy oil in Sportster?
Last Post: rich56
0 Be Careful Out There!
Last Post: RDHenley
Last Post: 1skullster1
0 The last of a dying breed...
Last Post: Bryan1976
Last Post: smilinbrad
0 Parts
0 Mikuni Knock Off "REVEALED" !!!
Last Post: davesz1r
0 Cam needle bearings correct install
Last Post: Nitro57xl
0 XR mutt race bike progress
flattracker1 (79), al sena (70), SwissXL (56), greendarren7 (49), martian (45), thadf (44), NOGOOD1%€R (37)
Old 2nd February 2014
scooby scooby is offline
Sportster/Buell Model #2: FXLR
Sportster/Buell Year #2: 1988
scooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant future
Originally Posted by cc rider View Post
Thanks everyone I feel much better. I always drain the tanks and clean the carbs and change the oil anyway in the spring before I start riding. Thanks again.
Close the fuel valve and run the carb dry. Or open the drain bowl screw and drain the bowl. Or both . Stabil or equal in the tank.
Don't forget the boats and yard equipment also.
rottenralph's Avatar
My bike turned 20 this year and to this point it has never been winterized. Still runs just fine.
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
Just to add more info to my post below, is that we live in Canada, and our Non-Riding season i.e. the storage season is about 6 months long each year
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
Old 3rd February 2014
baka1969's Avatar
baka1969 baka1969 is offline
Veteran Bubblehead
Sportster/Buell Model: 1200 C
Sportster/Buell Model #2: XLH 1000 Ironhead
Sportster/Buell Year #2: 1976
Other Motorcycle Model: 883 L
Other Motorcycle Year: 2007
baka1969 has a brilliant futurebaka1969 has a brilliant futurebaka1969 has a brilliant futurebaka1969 has a brilliant futurebaka1969 has a brilliant futurebaka1969 has a brilliant futurebaka1969 has a brilliant futurebaka1969 has a brilliant futurebaka1969 has a brilliant futurebaka1969 has a brilliant futurebaka1969 has a brilliant future
I was also going to say your bike is trashed and to ship it to me for proper disposal. But I was beat out.
I haven't winterized my bike the past two winters I've had it. I do ride it through the season though. Like I did today. A battery tender and some Seafoam in the gas tank is all you'd need. An oil change first thing this coming spring will be advisable.
2007 1200C
2007 883L sold
1976 1000 XLH Ironhead
May the number of surfaces exceed the number of dives by at least one
Skylar's Avatar
Skylar Skylar is offline
Sportster/Buell Year: 1972
Sportster/Buell Model #2: 1993 883
Skylar is an unknown quantity at this point
Stabil in the tank, I put the battery in the house and hook it back up in march or april, also I would drop and change the oil in the spring, that's what I always do. You'll be good.
Think positive and support your mother. She wouldn't want you going around depressed. Be strong brother.
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
The only downside to that is fuel evaporates over winter leaving behind deposits.
Whether one season's deposits will be enough to cause a problem is arguable.
But multiple seasons will build up more and more, and eventually be problematic. ESPECIALLY if you add E-10 to the tank because the ethanol can soften the deposits making them just fluid enough to get into and clog troublesome spots.
SOOOOO, I would suggest 2 things.
1. Next time I would add stabilizer to the fuel AND DRAIN THE CARB before storage.
2. This time, I would add Star-Tron or an additive designed to more completely dissolve deposits, which allows them to pass through the jets and be burned.
AB,Frank's Avatar
AB,Frank AB,Frank is offline
serial Canuckian
Sportster/Buell Model: XL1250C
AB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond reputeAB,Frank has a reputation beyond repute
Well I didn't do anything either so ...for gas ,I fuel up at home anyway,and there is stabil in the jerry cans before I fill them up at the station.
The tender is on the batt. I'll just change oil in the spring.
In three words I can sum up everything I've learned about life: it goes on.
hmiller's Avatar
hmiller hmiller is offline
Sportster/Buell Model: 883
Other Motorcycle Model: BMW K1200GT
hmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud ofhmiller has much to be proud of
My winterization procedure is to add another bungee or two to the tarp and put it on a tender.
MacSporty02's Avatar
MacSporty02 MacSporty02 is offline
Other Motorcycle Model: FXDLI
Other Motorcycle Year: 2008
MacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant future
I add fuel stabilizer and go out to the garage and run the bike for about 1/2 an hour so or go for a short ride between the cloud bursts. The weather here in the Pacific NW has been pretty mild the last few years with just one week in the 20's. My Sportie sits in an unheated garage and not on a tender, even though I have one, the reason for not is there is no power out in the garage I've run an extension cord out there but got hell from my brother so I just go out about once a week and run it.
Jordan5150's Avatar
Jordan5150 Jordan5150 is offline
Sportster/Buell Model: 883C
Jordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to beholdJordan5150 is a splendid one to behold
All I did this year was take the battery inside and put seafoam in the tank.
