Last Post: Model H
0 Tranny oil
0 ultima install without VOES
Last Post: supermotolew
0 Mikuni Knock Off "REVEALED" !!!
0 Why such heavy oil in Sportster?
0 Oh these college kids
Last Post: bordens
0 Yearly Allotment of Miles
0 Headwork
Last Post: Staffords
0 New guy from IL
Last Post: TamiSchall
0 73 XL 1000 Sportster - SOLENOID BYPASS
Last Post: 4th of July
Last Post: davesz1r
0 WTB: XR1200 Luggage Rack and Tailbag (OEM)
0 Chinese S&S carbs
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 1979 Ironhead Starter Washer, Bushing
Last Post: Tipofthelake
0 Highway cruise speed
Last Post: rich56
0 Be Careful Out There!
Last Post: RDHenley
Last Post: 1skullster1
0 The last of a dying breed...
Last Post: Bryan1976
Last Post: smilinbrad
0 Parts
0 Cam needle bearings correct install
Last Post: Nitro57xl
flattracker1 (79), al sena (70), SwissXL (56), greendarren7 (49), martian (45), thadf (44), NOGOOD1%€R (37)
Old 25th March 2015
Default Quick Reference Chart - Evos - What Parts / What Year
This is a chart of the variation in parts that appear on different years of Sportsters...
For instance, the size of the axles -and- the various brake pads used...
(I've been collecting this info for awhile from XLF and other sources)
Since the XLForum does not allow us to alter posts after a few days,
I'm placing the information here as a digital image file (GIF) so that
I can change that image file as I get updated or corrected information...
Please review the information and let me know what is right and what
needs to be corrected... And post your suggestions for what other
items I should include in the quick reference...
__o~~o__
IXL2Relax
Old 25th March 2015
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Nice works, thanks!
Old 25th March 2015
steelworker's Avatar
Other Motorcycle Year: 2016
Looks useful!
Comments:
The '98-'03 1200S ignition unit is under the seat.
Front brake master cylinders on single-disc models of that era were 9/16". The twin-disc 1200S, from '96-'03, had an 11/16" ffront master cylinder.
The twin-plug '98-'03 1200S also had W grind cams.
Old 25th March 2015
ReddTigger's Avatar
GREAT..
The bearings in your list as Timpken are actually...
Tapered bearings,
Timken company is one company that makes them.. they happen to be the most popular.
National
SKF
are other companies.
States I've Ridden in
71.3 hp 70.8 tq
Old 25th March 2015
Thanks decman - I hope it's useful to you...
Thanks Steelworker & Reddtigger
... that's the kind of help I need...
I incorporated your updates...
Most of the 2014 & 2015 data was simply copied from 2013 - Can someone verify that data?
Also, I collected some data about the Brake Pads - Can someone verify that column??
That column is to point out which year brake pads are the same type/fit.
I'm deliberately not putting any part numbers into the list...
__o~~o__
IXL2Relax
Old 25th March 2015
tmack-1's Avatar
tmack-1 tmack-1 is offline
Sportster/Buell Model: Sportster XLH1100
Sportster/Buell Year: 1986
Other Motorcycle Model: Speedway Green Horm
Other Motorcycle Year: 1972
tmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to all
Nice reference info. Could come in handy. Thanks!!!
1986 XLH 1100 (fixer-upper) // Engineers design things, Technicians make them work. --- 30% of being mechanical is confidence/30% is knowing to go slow when needed/30% is looking repeatedly at what you have/10% is dumb luck .
Old 26th March 2015
Originally Posted by IXL2Relax View Post
[B][SIZE="4"]Also, I collected some data about the Brake Pads - Can someone verify that column??
The part number for the '99 FRONT brake pads end with "-83", which denotes that they have been the same fitment from 1983-up. The REAR pad set part number ends with "-87", denoting that it's the same fitment from 1987-up.
The part number for '03 FRONT and REAR pads ends with "-00", denoting the same fitment from 2000-up.
The part number for '13 FRONT pads ends with "-04", denoting the same fitment from 2004-up. The REAR pads end "-07", denoting the same fitment from 2007-up. (The 2006 pads part number ends "-04", denoting the same fitment from 2004-up.)
The XR 1200 front and rear pads are different. Both front and rear pads fit all XR1200s from '08-13.
I couldn't confirm part numbers for 2014 and 2015 bikes.
So, to summarize:
SPORTSTER FRONT PAD TYPES: '83-'99; '00-'03; '04-'13 (and maybe still)
SPORTSTER REAR PAD TYPES: '87-'99, '00-'06; '07-'13 (and maybe still)
XR1200 FRONT AND REAR PADS: '08-'13
Old 26th March 2015
Thanks again Steelworker - I've updated the chart with your data...
And I think I finally have an accurate listing of the Frt Master Cylinder Bores...
(although the -R models may still be one-off - not sure yet)
(I took off the 98-03 Sport MC reference since it appears all 1200 models used 11/16)
I hope this can become a sticky because it should be helpful directly to those
looking for information and to those who are trying to help others with their
extensive knowledge of how all these variations interplay with each other...
__o~~o__
IXL2Relax
Old 27th March 2015
I've added a date at the end of the year list.
If you've previously copied the chart, you can now check
the date currently showing to see if your copied chart is up-to-date...
As I get more information (or corrections) I'll continue to add to
or correct the information in the chart...
I'm adding this list of search terms to help others find this thread\
when they are looking for a particular subject.
Butterfly Carburetor
Keihin CV Carb CV40
Fuel Injection
4Speed 5Speed Belt Width Teeth Sprocket
Speedometer Gas Fuel Tank
D-Grind W-Grind Cams
Ignition Module
ECM ICM Timer Pickup
Nosecone Underseat VOES MAP
Head Bathtub Hemi Lightning Thunderstorm XB
Bearings Timken Sealed
Axle Brake Pads Master Cylinder Bore
__o~~o__
IXL2Relax
Old 4th May 2015
(1) Can someone tell me when the front turn signals also became running lights (on the standard models)?
(2) Can someone tell me if the current standard models have rear running lights with the turn signals? What year did that start?
Thanks
__o~~o__
IXL2Relax
