0 Why such heavy oil in Sportster?
0 Oh these college kids
Last Post: bordens
0 Yearly Allotment of Miles
0 Headwork
Last Post: Staffords
0 New guy from IL
Last Post: TamiSchall
0 Tranny oil
Last Post: Billy1200
0 73 XL 1000 Sportster - SOLENOID BYPASS
Last Post: 4th of July
Last Post: davesz1r
0 WTB: XR1200 Luggage Rack and Tailbag (OEM)
0 Chinese S&S carbs
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 1979 Ironhead Starter Washer, Bushing
Last Post: Tipofthelake
0 Highway cruise speed
Last Post: rich56
0 Be Careful Out There!
Last Post: RDHenley
Last Post: 1skullster1
0 The last of a dying breed...
Last Post: Bryan1976
Last Post: smilinbrad
0 Parts
0 Mikuni Knock Off "REVEALED" !!!
Last Post: davesz1r
0 Cam needle bearings correct install
Last Post: Nitro57xl
0 XR mutt race bike progress
flattracker1 (79), al sena (70), SwissXL (56), greendarren7 (49), martian (45), thadf (44), NOGOOD1%€R (37)
Old 22nd May 2020
herostar herostar is offline
Sportster/Buell Model #2: XB9R
herostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really niceherostar is just really nice
The first few years of EFI had issues with the fusebox getting corroded because they put it in a spot that's prone to getting wet. They also had the ECU under the seat which limits what aftermarket options are available. I think they changed both these things in 2009 or 2010.
2007 XL1200R - Denver, CO
Old 22nd May 2020
You can have a look thru the various sections of the Sportsterpedia to see what issues may be mentioned - and some aftermarket products represent issues that may arise:
http://sportsterpedia.com/doku.php/t...cal_categories
The rubber mounts themselves will need to be monitored and replaced when they sag. Battery cables seem to be a constant issue on Sportsters - some have used tyraps around the mounting bolt to prevent it from loosening.
Most Sportsters from the factory have several areas that are attended to early - Seats, Suspension, Air Cleaner & Exhaust. The first two for comfort reasons & the last two for performance reasons.
I hope your son enjoys the new ride - Any time in the wind is better than doing something else...
Old 23rd May 2020
SwissXL's Avatar
SwissXL SwissXL is offline
Sportster/Buell Model #2: 1200N Nightster
Sportster/Buell Year #2: 2011
SwissXL is a splendid one to beholdSwissXL is a splendid one to beholdSwissXL is a splendid one to beholdSwissXL is a splendid one to beholdSwissXL is a splendid one to beholdSwissXL is a splendid one to beholdSwissXL is a splendid one to beholdSwissXL is a splendid one to beholdSwissXL is a splendid one to beholdSwissXL is a splendid one to beholdSwissXL is a splendid one to behold
Indeed the forum already proves an amazing asset! It's quite a change after his Yamaha. As I told my son: "you've got to earn the right to ride this one"
2011 Nightster; Ape hangers w cable kit. Used to ride a '77 Ironhead w straight pipes
Old 24th May 2020
BSA Bob BSA Bob is offline
Sportster/Buell Model: XL883n
BSA Bob has a reputation beyond reputeBSA Bob has a reputation beyond reputeBSA Bob has a reputation beyond reputeBSA Bob has a reputation beyond reputeBSA Bob has a reputation beyond reputeBSA Bob has a reputation beyond reputeBSA Bob has a reputation beyond reputeBSA Bob has a reputation beyond reputeBSA Bob has a reputation beyond reputeBSA Bob has a reputation beyond reputeBSA Bob has a reputation beyond repute
My 2010 883 has about 72000 miles on it. The dealer services it. The only major failures have been the rubber mounts, once at maybe 55000 (I forget really) & coming up for new ones again.
The steering head bearings can be felt when the bike's on the stand but not otherwise & no handling effects.
Just a few small things, essentially consumables.
And once in a while the speedo takes it into its head to stop working. Documented on this forum & fixed by stopping & restarting.
Overall I'm very happy with it mechanically.
Old 24th May 2020
SwissXL's Avatar
Thanks BSA Bob
Old 24th May 2020
SwissXL's Avatar
Thanks, indeed I crossed the mentions of these early series annoyances
Old 26th May 2020
screndname's Avatar
screndname screndname is offline
Sportster/Buell Model: 883c & 07 nightster
Sportster/Buell Model #2: 1200 nightster
screndname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud ofscrendname has much to be proud of
I have an 07 I bought used 3 years ago.
negative battery terminal, I made one and rerouted it.
one time time in first month the bike would not start when I pushed the button. next day ordered and installed a Terry components fail-safe starter switch(their are cheaper versions if that's your thing). I have used it 2 times so far, its a lot easer then a push start.
Old 26th May 2020
xElvis's Avatar
xElvis xElvis is offline
xElvis has disabled reputation
I have an '08 883 with 110k miles. As others have said, the clutch plate. Mine blew up at around 35k miles. Have heard of the oil gear, battery terminals/cables, and rubber mounts being a problem, but haven't had those myself, yet. By '08 the fuse box issue was fixed, and I don't think that they moved it between my year and your son's '11.
xElvis - DOT Certified Cage-Free - '08 883 ~100k miles
Old 29th May 2020
SwissXL's Avatar
Thanks for the input @xElvis it seems those are the usual suspects, hence points of attention for the current Sportster.
I peeked at the electricals of my son's 2011 Nightster and was surprised to see that most wires and modules are (still) "wet", meaning they are exposed to get wet. And they don't appear to be particularly waterproofed either. That surprises me.
Can you wash a current Sportster with high-pressure cleaners or ride under intensive rain without trouble? (not that I would do the latter but life is life...)
Old 29th May 2020
Bikeaholic Bikeaholic is offline
Sportster/Buell Model: xl1250
Bikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud ofBikeaholic has much to be proud of
07 and 08 are the same fuse housing problems. Maybe even 09?
The problem is that water could collect in the funnel/tube type harness used to hold the wiring and then directed down onto the fuses area .
07-09 models have the ecm on the top of the back fender, under the seat. So be aware of seats you may want to change too.
