0 WTB: XR1200 Luggage Rack and Tailbag (OEM)
Last Post: kodylk08
12 Crankcase breathing?
Last Post: mikaelson
0 Tranny oil
0 Parts
Last Post: XL Ed
Last Post: Model H
0 ultima install without VOES
Last Post: supermotolew
0 Mikuni Knock Off "REVEALED" !!!
0 Why such heavy oil in Sportster?
0 Oh these college kids
Last Post: bordens
0 Yearly Allotment of Miles
0 Headwork
Last Post: Staffords
0 New guy from IL
Last Post: TamiSchall
0 73 XL 1000 Sportster - SOLENOID BYPASS
Last Post: 4th of July
Last Post: davesz1r
0 Chinese S&S carbs
0 Sportster Fork Upgrade
Last Post: PetesPonies
0 1979 Ironhead Starter Washer, Bushing
Last Post: Tipofthelake
0 Highway cruise speed
Last Post: rich56
0 Be Careful Out There!
Last Post: RDHenley
Last Post: 1skullster1
0 The last of a dying breed...
Last Post: Bryan1976
flattracker1 (79), al sena (70), SwissXL (56), greendarren7 (49), martian (45), thadf (44), NOGOOD1%€R (37)
Old 26th May 2020
robbie202's Avatar
robbie202 robbie202 is offline
robbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant future
Default mixing brake parts
one thing leads to another and now everything on my handlebars has been completely changed over time including the bars.
new master is made for dot 4.
do i
A: use the existing caliper but service it so there is no trace of the old dot 5 fluid?
B: upgrade the front caliper to one that is meant for dot 5?
2020 KLX250
1977 GL1000
Old 26th May 2020
robbie202's Avatar
i guess C would be to just flush out the 5 caliper with the 4 fluid since the type of fluid is listed on the reservoir not the caliper.
Old 26th May 2020
where you get into trouble is when you have ABS system.
at one time, even hd used dot 5 but with newer systems, the chance of cross mixing, they just use dot 4.
the big issue is that dot 5 does not hold water and glycol base will and if mixed, the water will inter-phase between the two and will corrode the aluminum parts. most rubber parts can handle either, except the ABS.
Old 26th May 2020
robbie202's Avatar
non-ABS 2003 and the lever and lines are new.
so maybe i could just use 5. it would match what has been previously run through the caliper.
Old 26th May 2020
i use dot 5 on my 01 sport and 74ch
Old 26th May 2020
robbie202's Avatar
Right. The caliper is supposed to have 5.
Sent from my SM-G970U using Tapatalk
Old 26th May 2020
Hippysmack's Avatar
What size bore is the new master?
Old 26th May 2020
robbie202's Avatar
Old 26th May 2020
Hippysmack's Avatar
I was just thinking you wouldn't want to go smaller than the original bore size or you may not get brake lever travel.
if using stock calipers.
So what is the stock bore size?
Old 26th May 2020
robbie202's Avatar
