0 Leineweber camshaft
Last Post: RDHenley
0 Mid or forward controls.
0 buckhorn bars
Last Post: 11alan111
Last Post: Larry May
0 Next please (ICM Learning Cycle)
Last Post: 93trident
Last Post: SLW210
0 Powerraythor conversion
0 Getting Hammered
5 02 Sporty speedometer wiring
0 Dynojet Target Tune and/or autotune with PV
0 A Day in the Life...
Last Post: Bigshankhank
0 The show me your winter beater thread
Last Post: mac93
0 Timing
0 Fat Ironhead?
0 Locked up rear wheel
ironhead, solenoid, starter, starter relay
Old 1st July 2012
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
Originally Posted by tony108 View Post
Yes Low, that is the problem I'm having. Far as the solenoid, it went back together the same way it came apart. The only parts that there were to really fool with were the two bolts on the solenoid (bhind the oil lines), the foam seal between the solenoid and the primary, and the long spring. Didnt see any issues getting them back together when reassembling.
As far as the voltage, I havent put a meter to it yet but thats what I'm doing soon as I have breakfast.. Just so I'm sure what I'm looking at, on the front of the solenoid there's three connection posts. The top one is the largest and comes from the positive battery, the middle one is the smallest with a small wire going to it. not sure of it's function. Then there's the bottom post. It apparently runs the starter itslef.
What kind of reading should i get from these when the start buton is pressed? What should I get when it isnt pressed?
I'm pretty good at figuring out stuff, I'm just not sure what clues i should be looking for,
The small wire is the one that energizes the solenoid, it comes from the starter relay. When you hit the starter button, the starter relay is pulled in and delivers 12v to the solenoid on the small terminal, energizing its coil to bridge the two larger wires together and power the starter motor.
When you release the start button, you should lose the signal to the start relay, which should then remove the 12v input to the small term on the solenoid. Allowing the solenoid to relax and remove power from the starter motor.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
Old 3rd July 2012
tony108 tony108 is offline
Sportster/Buell Model: XLS1000
tony108 is an unknown quantity at this point
well. took the battery our and checked ALL the wires in the circuit board. made sure all the studs were covered with heat shrink, traced every wire for short. Found nothing. I bought a new battery yesterday. Installed it yesterday evevning and let it charge over night. I cranked it a few minutes ago and got same thing, starter stays engaged after the engine starts and I've released the start buton. I'm gonna take the solenoid back off and tear into it and see if there's anything going on inside this thing. If i cant find nothing, I'm gonna order another new one and hope i got a piece of crap with this one.
Anyone got anymore ideas about what this could be?
Old 3rd July 2012
hugie03flhr hugie03flhr is offline
Sportster/Buell Model: Buell M2
hugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enough
Use the return spring from your old solenoid and use a test light to see if the small wire powering the solenoid goes off when you let go of your button.
Old 3rd July 2012
79sportster 79sportster is offline
Sportster/Buell Year: 1979
79sportster has disabled reputation
Default clicking
i tried to start my bike today and all i got was a clicking sound ,too.
it's 97 degrees out there right now.maybe the bike's smarter than i am.
