0 55* this morning
Last Post: Skeezix
0 Microsquirt EFI Conversion
Last Post: Randy_rots
0 Chasing a generator noise
0 KBS tank sealer
Last Post: Len PA
0 starting rollers
0 Tools
Last Post: ReddTigger
0 Covered shocks
Last Post: Reverend G
0 Potato-potato
0 XR750 resurrecting
Last Post: Big Al
0 carbs?
0 77xl sportster
Last Post: Mr Snoid
Last Post: bklyngeezer
0 2007 883R From Sunny Old England!
0 "She" bolts
0 Long vs short stem mirrors for 1980 fitment
Last Post: blk80bike
0 Better Brakes
Old 1st December 2013
MacSporty02's Avatar
MacSporty02 MacSporty02 is offline
Other Motorcycle Model: FXDLI
Other Motorcycle Year: 2008
MacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant future
Got photos for those that are slow...like me...LoL!!
ReddTigger's Avatar
I'll take some tomorrow..
States I've Ridden in
71.3 hp 70.8 tq
Desertfox's Avatar
Desertfox Desertfox is offline
Sportster/Buell Model: 2001 883 Custom
Desertfox has disabled reputation
It will probably live longer then oem.I ordered then today,.should have then next week
Been through this myself (twice). Once for the throw out bearing and once for the main clutch hub bearing. Bikes that are steadily in city rush hour traffic or otherwise clutched a lot are prone to this. I would recommend an OEM replacement. It has been my experience to be the best route. Most (but by no means all) after market stuff tends to be junk.. and using a bearing not specifically designed for this purpose just because it fits is not necessarily a wise choice. It is amazing how much you can spend chasing what is cheap.
BTW I would recommend changing the main clutch hub bearing as well while you are at it . Save you an annoying problem that you will probably have sooner rather than later. If the throw out bearing goes, your main clutch hub bearing is probably not far behind .
If you hate me, I've probably given you just cause. There, feel better?
wedge's Avatar
wedge wedge is offline
There are a lot of good American bearing manufacturers out there, so as long as it's not from Thaipanschewan I would run it.
And who makes the Harley bearing? It could be manufactured in a desert somewhere, between sandstorms for all we know.
I do agree that some Harley parts seem to be better than after market, and so far the battery seems to be one of them, unless you get a high tech type battery I suppose, so there are no given answers on quality. I look into every part and evaluate what I think it's worth. For instance I just paid way too much for a rotor with a brand name that I am not fond of, but the rear on these things is a bit quirky, so I went with the best possible floating rotor available. I also use EBC Brake pads, sintered in the rear, and straight organic in the front to balance out the braking. Harley pads eat rotors and are way to grabby in my opinion.
Old 2nd December 2013
ReddTigger's Avatar
Doing mikes build, I've had LOTS of OEM bearings, So far only a handfull have been made in USA.. I had one. that said it was made in Germany on the outer package.. then the bearing said made in brazil. and HD isn't ONLY using TIMKEN (they used to use them exclusively) these days either.. which is what I replaced most of the bearings (when I could find them) with.
Old 3rd December 2013
BobWLR's Avatar
BobWLR BobWLR is offline
BobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of light
Bearings I removed from my tranny, clutch hub etc were FAG bearings. Replacements from HD were also FAG. Zippers used PEER bearings (made in China and they personally garrantied them as top quality) in my Trapdoor. Bearings ordered from aftermarket sources may be All Balls Gorilla bearings ??? Hard to find anything made in the USA anymore. The AutoClutch I installed should eleminate any throwout bearing issues but then the throwout bearing is much cheaper to replace haha.
Edit: Your local bearing house is a good source. They even had FAG bearngs but almost all the bearings I sourced from them were sealed type. I just poped the seals off. They are all standard bearings, no mystery stuff, The Part# is etched on the side of the race as id the country of origin. The output bearing was tha same as a Big Twin.
ReddTigger's Avatar
Finally got the pictures..
with the shoulder of the release plate facing downwards, (same way you would install bearing)
it's hard to see what it SHOULD look like installed because of the ridge.. so here's another of what
it SHOULD NOT Look like..
Old 29th August 2019
Are there any pictures of the correct FACE-OUT/FACE-IN installation? I found this video and both sides look the same (I think).
https://www.youtube.com/watch?v=JZutYyY1yrY
This is what I ordered:
https://www.amazon.com/FAG-7200B-TVP...XDGKJBDVHCCSWM
The Sporsterpedia page on the Clutch has that picture (above) from Reddtigger:
http://sportsterpedia.com/doku.php/t...r_ball_bearing
Look at the diagram that accompanies the picture (see below)... Pay attention to the thickness of the races and the direction they are installed...
wedge's Avatar
That drawing really shows it good.
