0 question for our machinists
Last Post: Yakcm2
0 Fact or fiction?
0 Race tracks are harsh environments
0 You can't tour on that!!!
Last Post: RDHenley
Last Post: herostar
0 Black Friday/Cyber Monday Showoff Thread
Last Post: herostar
0 XLCH Plunger Seat Kit
Last Post: FatboyBill
0 hi all
Last Post: early iron
0 Swingarms
0 the roadster make more power ?
0 supply oil line seeping
0 Question on priming motor for kickstart
0 Interview of My Expieriences Riding in the Iron Butt Rally
0 Hydraulic Lift For XL
0 3.5" straight riser
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
0 Very Loud Backfiring (among other things)
Last Post: Nacs
  #31
Old 12th May 2019
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Originally Posted by NGOT8R View Post
Ok thanks cyco. What about the large washers that sit atop and below the preload spacers? Can those be purchased at a local hardware store too, or are they dealer only items?
Extra washers and a piece of PVC pipe were included with my RaceTech springs.
FRSP S29380XX springs.
Old 12th May 2019
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to behold
That's even better! Race Tech it shall be. Thanks Tomcatt.
Old 16th May 2019
I was able to order an oem spacer and necessary washers from the dealer, so that the internals of both fork legs will match. I also received my cartridge eliminator kit in the mail. Both damping rod are 11" long, but have two 2" spacers that can be used if the end user opts to run 9 1/2" damping rods instead of 11", which would raise the front end. Additional parts supplied with the kit are one spring and one aluminum end cap that goes on the end of one damping rod. can anyone confirm whether each damping rod in pre 2016 Irons have an aluminum end cap and spring? Thanks
Old 16th May 2019
Dazed & Confused
Your left fork leg (left sitting on the bike) has the cartridge. Right side has a damper rod that doesn't damp but does have the "aluminum end cap" which is the bottoming stop, "oil lock" per the parts book, and a (short) spring which is a topping spring.
Old 16th May 2019
That’s what I was hoping to hear. Thanks Tomcatt!
