0 magneto twin plug heads
Last Post: spuggy
0 H4 LED Conversion - write up with photos
0 Help identifying brakes
Last Post: bobandy
Last Post: SCarty
0 weld on hardtail
0 Down on oil
0 CV Carb hesitation
0 Mounting seat
Last Post: guidowisozk
0 TC88A EX lower MAP settings
0 Magneto insulating block removal
0 Cosmo's ECM Relocation Mod
0 i want a narrow/standard mustang vintage
5 Wet Dream, Ever Have One?
Last Post: Joe_jeep
0 Round Air Cleaner Poll
Last Post: Joe_jeep
0 Clutch Q
Last Post: wrkdWS6
0 Chinese S&S carbs
Last Post: Hornsmith
Last Post: BWP 5p
0 Rear wheel alignment
Old 30th August 2010
BlackBikeDave's Avatar
BlackBikeDave BlackBikeDave is offline
BlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant future
Default DIY 12v Electrical Outlet
Got this idea from another forum and couldn't find it here so sharing it now.
Many times I have got all ready for a ride and my cell has 1 bar left..and I gotta go when the road calls...so I made one of these. If you can solder its very simple.
Got the plug end at a non HD bike shop for a battery tender. $6
Got the marine grade 12v power point(cig lighter) at Walmart. $3
Got the USB insert at Harbor Freight. $3
Helps make it neat if you have some heat shrink tubing which you can get at Home Depot or Radio Shack. 2 different sizes. One for the individual wires you will solder and a larger one to seal the whole deal.
(The female end on the bike is gonna be the + and the male end the -.
On the plug you are soldering the male will be the + and the female -.)
***Remember that the + and - lines will be reversed on the part you are making as they fit together with the battery tender plug that is hard wired on the bike...so if you make the male ends on both plugs positive when you connect them they are going to be reversed and it won't work***
***Also there is a 7.5amp fuse inline on the + leg of the plug that is hard wired on the bike...if it's blown you need to change it or this won't work***
I say this cause I made these stupid mistakes...
I clipped of the (wing parts) on the 12v outlet and filed the corners smooth so I can slip it in my pocket.
You don't need the USB adapter if you have a regular car cell charger.
Hope this is good info for anyone in need.....Love the DIY on the cheap!!
chardhin's Avatar
chardhin chardhin is offline
Sportster/Buell Model: xl 883c<1212
Other Motorcycle Model: RoadKing Classic
Other Motorcycle Year: 2010
chardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond repute
was gonna do the same, I wanna mount the adapter in my saddle bag. been thinking on it for a while. nice of you to beat me to the punch!
I find it hard to believe that "everybody" was Kung Fu fighting.
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
I did the same thing except I just crimped the connectors on the wires connected to the power outlet and connected them to the battery. No tender harness needed.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Old 13th March 2014
xtremeskier97 xtremeskier97 is offline
Sportster/Buell Model: XL1200s
Sportster/Buell Model #2: XL1200s Anniversary
xtremeskier97 is a name known to allxtremeskier97 is a name known to allxtremeskier97 is a name known to allxtremeskier97 is a name known to allxtremeskier97 is a name known to allxtremeskier97 is a name known to allxtremeskier97 is a name known to allxtremeskier97 is a name known to allxtremeskier97 is a name known to allxtremeskier97 is a name known to allxtremeskier97 is a name known to all
I know I know...Holy Thread Revival Batman...but I'd rather not add more threads if there is already one with most the info I need.
My question is, if I dont already have a battery tender for...tending the battery....do I just buy 2 of the battery tender cables in the picture to complete this job?
I need to run a GPS for a trip I'm taking with my son next month.
Thanks!
Old 14th March 2014
ReddTigger's Avatar
If you have a solid mount. you can get a metal bracket for cigarette lighters at walmart, and wire it to an inline fuse directly to the battery.. Then mount the metal bracket to the battery strap..
I'll take a pic.. later.
States I've Ridden in
71.3 hp 70.8 tq
Old 14th March 2014
That'd be awesome!
What amp fuse is recommended for this?
Old 14th March 2014
sportsterdoc's Avatar
Originally Posted by xtremeskier97 View Post
That'd be awesome!
For a short run of 16 gauge wire, 15 amp would be max and 10 amp would be conservative. Fuses should be determined by wire size and then may be reduced if the anticipated load is less and/or if the socket is rated for less.
Old 14th March 2014
ReddTigger's Avatar
Took a pic with my phone. This is how mike attached his..
Old 14th March 2014
ReddTigger's Avatar
We're using a 10 amp fuse..
Most inline fuse wires are long enough. Just put a ring terminal on one end (to goto battery) and a fem as le spade on the other to attach to socket
Old 15th March 2014
Ok, so this is what I was thinking...
Thoughts/Concerns?
Oh, and dont judge on the Dunlop....it is being replaced with a Commander II before the trip!
