0 90" With an HSR45 Setup
0 Speedo ideals
Last Post: dodgetrucken
0 Long intake
0 Who wants to have a ride out
0 Glyptal?
Last Post: Scott
0 Oil lines..
Last Post: Scott
0 Which Battery?
Last Post: Bikeaholic
Last Post: Clevspeed
0 Photo bucket
Last Post: RDHenley
Last Post: RDHenley
0 Post your paint questions here!!!!!
Last Post: Bigshankhank
Last Post: stikflote
0 Ironhead 1000cc 1971 Help with clutch assembly
0 Head work
0 More PhotoBucket Horrors...
Last Post: Bob F
0 My 1250 to 1275 build
Last Post: neilp
Old 22nd February 2019
rog rog is offline
Sportster/Buell Model: XL883
Sportster/Buell Year: 1986
rog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura about
Default Hard to shift
Hey,
I just broke open the primary case on an XL883 1986 to replace the clutch cable. I am using forward controls. Since doing so, I am having trouble changing up, it has become physically difficult and hard on my foot! The clutch feels perfect, and the bike stands still with clutch engaged, and it lets out nicely with no slip when power applied. The clutch adjuster is adjusted to its first range, and by winding it open it becomes slippy and the clutch becomes less responsive. Any ideas of what I may have changed that creates the issue?
Thanks, Rog.
Air-Cooled Forever
What type of 'Forward controls' are you using? Factory, aftermarket brand or home-made?
Some of the aftermarket brands seem to have their leverage points "off" slightly making them harder to shift and some are so loose they rattle and over-tightening them is common. Sometimes, just lubing the joints with motor oil will make them shift a lot better.
Old 23rd February 2019
rog rog is offline
Fixed her! When I put the gear change back on I had moved it a couple of degrees off from where it was. The shifter position felt the same but it wasn't able to get full leverage up. Moved it on the spline and hey Presto!
Air-Cooled Forever
Good to hear. Been there, done that!
