0 New to me bike - 2004 1200r -did I miss anything
Last Post: chief100
0 Newbie
0 grinding noise.
4 The no-debate OIL POLL
0 mystery leak
Last Post: 11ccd13
0 New LED headlight bulb. Highbeam aim wrong.
Last Post: Four Speed
0 Oil pump Iron 1000 1979 bizarre.....
Last Post: Bstrdbike
Last Post: joes95bobber
Last Post: walterxlh
0 Could this be an overheating issue?
14 1974 Ironhead sportster xlch
Last Post: Ltdr13
0 71 Iron
0 Street Tracker
Last Post: garyajaz
0 Longer Rear Brake (Foot Brake) Lever?
0 ***DK Custom-*NEW* On Our Site-Scratch & Dent Specials***
0 Dynojet Power Vision 2
0 New member
Last Post: Calcustom
0 Clutch ramp outer
Last Post: Harry
0 ***DK Custom-Beat The Heat-Save 10% on Cooling Components***
0 Rolling Thunder
Last Post: ezmerf
0 Leaky oil drain plug.
Last Post: ezmerf
0 Lake Erie Ride Alums?
Last Post: Shark Doctor
dtw757 (65), XLH75Rider (64), JRLang13 (57), Shaerona (55), christophe (52), collectovince (51), buckethead (41), Hang_Em_High (39)
Old 22nd February 2019
rog rog is offline
Sportster/Buell Year: 1986
rog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura aboutrog has a spectacular aura about
Default Hard to shift
Hey,
I just broke open the primary case on an XL883 1986 to replace the clutch cable. I am using forward controls. Since doing so, I am having trouble changing up, it has become physically difficult and hard on my foot! The clutch feels perfect, and the bike stands still with clutch engaged, and it lets out nicely with no slip when power applied. The clutch adjuster is adjusted to its first range, and by winding it open it becomes slippy and the clutch becomes less responsive. Any ideas of what I may have changed that creates the issue?
Thanks, Rog.
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
What type of 'Forward controls' are you using? Factory, aftermarket brand or home-made?
Some of the aftermarket brands seem to have their leverage points "off" slightly making them harder to shift and some are so loose they rattle and over-tightening them is common. Sometimes, just lubing the joints with motor oil will make them shift a lot better.
Old 23rd February 2019
rog rog is offline
Fixed her! When I put the gear change back on I had moved it a couple of degrees off from where it was. The shifter position felt the same but it wasn't able to get full leverage up. Moved it on the spline and hey Presto!
Toejam503's Avatar
Air-Cooled Forever
Good to hear. Been there, done that!
