Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Styles > Sportster Motorcycle Custom Finishing
0 2012 883 miss that comes and goes
Last Post: tussuck
0 Mac exhaust
Last Post: moparnut72
Last Post: oupa
0 who rides with a Flyscreen (or similar) AND an open face helmet?
Last Post: 83XLX
0 6 speed
0 New member
0 More oil return questions
Last Post: Scott
0 883 cc >> 1200 cc big bore conversion
Last Post: lovevoodoo
Last Post: HDCUSTMBUILD
0 Brake pedal adjustment on 09 Custom
0 Tools
7 Ironhead yes or no
0 SBS Project - Sportster Chop w/ Lots of Photo's
0 forged pistons?
0 Sportsterpedia Progress
0 IH rearsets and giant stud
Last Post: dewjantim
0 1250 break in map for tc88a
0 TC88A EEPROM or FLASH
3 Shaky Dave Recovery
0 Getting Hammered
Last Post: Bryan83taco
0 Power outlet
Last Post: RDHenley
Old 2nd March 2013
DGibsonOne's Avatar
DGibsonOne DGibsonOne is offline
Sportster/Buell Model: 1200 xlh
Sportster/Buell Year: 1990
DGibsonOne is an unknown quantity at this point
Just make sure it is thoroughly cleaned and spray right over the grey finish. I just did mine with the Harley wrinkle black and it looks great so far (after 24 hours of drying, waiting till tomorrow to unmask it.)
1990 Sportster 1200xlh
Old 2nd March 2013
gpsjr10's Avatar
gpsjr10 gpsjr10 is offline
Sportster/Buell Year #2: 2002
Other Motorcycle Model: IH hardtail project
Other Motorcycle Year: 1974
gpsjr10 is a glorious beacon of lightgpsjr10 is a glorious beacon of lightgpsjr10 is a glorious beacon of lightgpsjr10 is a glorious beacon of lightgpsjr10 is a glorious beacon of lightgpsjr10 is a glorious beacon of lightgpsjr10 is a glorious beacon of lightgpsjr10 is a glorious beacon of lightgpsjr10 is a glorious beacon of lightgpsjr10 is a glorious beacon of lightgpsjr10 is a glorious beacon of light
I just used masking tape and newspaper and painted mine took about an hour to mask, and 10 minutes to paint. I believe I used Duplicolor engine paint, Semi-Gloss Black. Been there for 3 years now and still looks like it did the day I painted it. I used Gunk engine degreaser (the gel or foamy kind works the best) and a nylon detail brush to scrub the tough spots before I masked it off. You can get everything at any local auto parts store.
Old 2nd March 2013
wildgoose450r wildgoose450r is offline
Sportster/Buell Model: Nightster 1200
wildgoose450r is an unknown quantity at this point
Foil and lots of masking tape! Also, if you can find thread protectors, you can put them over the bolt heads to keep from painting them! Works very well!
Old 28th February 2017
Shroomster Shroomster is offline
Shroomster is an unknown quantity at this point
Originally Posted by Maustarman View Post
I just did my engine ... No tear down ..just masking.
Here some pics ..before..during.. & after
Man, that looks pretty good!! I'm thinking I might have to do mine. Hahaha
Sent from my SM-G900V using Tapatalk
Old 12th August 2017
Guzzi850 Guzzi850 is offline
Sportster/Buell Model: 883
Other Motorcycle Model: Guzzi lemans
Other Motorcycle Year: 1976
Guzzi850 is an unknown quantity at this point
Don't know if they are still around but Kal Guard had a satin black paint I used to paint my Suzuki back in the 80's.
Old 27th September 2019
Hellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud of
I painted mine last weekend. The foil idea is great. I washed the bike since it needed it anyway and Gunked the engine using a toothbrush where needed.
I used Rustolium satin (it's what I had) on the cases and grill paint on the head and jugs.
I may go over the cases with flat later. It's not the greatest job but she's a go-er not a shower.
NLXL's Avatar
NLXL NLXL is offline
I would not tear down a perfectly healthy running bike for a paint job. I would just remove everthing that is not difficult to remove but just in the way. I would remove the obvious: Aircleaner, carb, exhaust and what not. Use masking tape and go meticulous and take your time.
<edit: didn't realize it was an older thread>
Patagonia to Alaska
https://www.itchyboots.com/
NLXL's Avatar
Looks great! Never thought of using foil.
Old 30th October 2019
I got the foil idea from a couple threads on here.
Comes off a lot easier than tape, too!
