Last Post: Vohnsen
5 Terminology Sticky?
0 Hello from Murcia-SPAIN
Last Post: heyshott 81
Last Post: oupa
Last Post: Darkseacret
0 How to start a 1967 Sportster XLCH
Last Post: JackPrice53
0 XB9 crank?
Last Post: Curbside
0 Jutland 05-31-16
Last Post: slcharger
0 XR1200 belly pan on an XL?
Last Post: CT XR rider
0 POLL: Vance and Hines
Last Post: Bama Lee XLC
0 And so it begins......
Last Post: Texassporty06
0 Spokes or Mags
Last Post: Desertfox
0 Spokes question
Last Post: Doc308
Last Post: Nayra
0 Fuel Pump Problems
6 Is Your SPORTSTER...
0 How stock is your bike
fhilliard (78), paulmo (74), Beloved (48), Mr. Cro (48), Chopper Duke (40), Danny3nose (38)
90ci, big bore, engine builder, hammer performance, patriot defender
  #41
Old 24th May 2016
MatHormell's Avatar
MatHormell MatHormell is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: Buell XB12R
Other Motorcycle Model: Yamaha
MatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond repute
Just finished altering your valve angles. About a 2 hour job. Very tedious to do. Lots of very precise setup. Everything has to be dead nuts accurate for it to come out right. I spend a lot of time shimming each head in the fixture to get it perfectly square and then doing the indicating to find the exact correct spot. Then hold my breath while I cut it and pray everything is right.
Already did yours Ryan.
Both sets came out perfect.
Post up a pic if you find some spare time!!
Sent from my SAMSUNG-SM-G935A using Tapatalk
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HAMMER PERFORMANCE Intake Manifold
HSR 48 Miunki
XR1200 Crank Conversion W/ Case Mod 34T
HAMMER PERFORMANCE Sledge+ Head Work
2.020" Intake and 1.630" Exhaust Valves
Conical Valve Springs
S&S Premium Lifters
HAMMER PERFORMANCE Billet Push Rod Bases
Barnett Clutch Hub With Scorpion Clutch
Dynatek 2000i
R&D MOTORSPORTS- TRANSMISSION WORK-REM ISF
WorldWideBearings
Patriot Defender Exhaust
Old 25th May 2016
MatHormell's Avatar
Originally Posted by madnss View Post
Looking good Mat, but I think you changed your mind around 8 times haha
Someone on the quad page went somewhere around 50-51.5 on a 48 mikuni
I think the 48 will do just fine. I just orderd some more main jets over 200
Hmm and still kept the taper? I was lookong at those lectrons all the way up to 55, just don't know how well mounting it to Filter will go lol
Old 25th May 2016
MatHormell's Avatar
I'm sure the 48 will be enough for a 90" anyways
Old 25th May 2016
rocketmangb's Avatar
Dont be so sure !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 25th May 2016
MatHormell's Avatar
Dont be so sure !
I'm always down to test stuff!
Old 25th May 2016
rejeanprimeau's Avatar
Kevin will provide a mounting adapter for your application.
Old 25th May 2016
splineman's Avatar
splineman splineman is offline
Other Motorcycle Model: Honda GB400
Other Motorcycle Year: 1987
splineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond repute
Awesome build.
I just ordered a bunch of stuff to go 90" with my bike from Hammer...4 to 6 weeks away yet.
Not as crazy as your one tho....nice work!
Old 25th May 2016
MatHormell's Avatar
Originally Posted by splineman View Post
Awesome build.
Thanks man!! I dont think any sporty @ 90" is gonna be disappointing either way! lol Nice to see so many taking the extra effort to punch these things out!
Old 25th May 2016
MatHormell's Avatar
Gotcha, I may call him up and pick his brain a bit.. Gonna push the 48 as far as I can then go from there, I really like how the 42 performed so I'm sure ill be satisfied with the 48
Old 25th May 2016
Default Crazy Kiwi !
Awesome build.
Bout sums it up !
