Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Engine Conversions
Last Post: Fivecats
0 Getting old is a bitch!
0 Allegheny National Park III
0 Sportster S on the dyno
Last Post: Fivecats
0 1967 on FaceBook. Florida.
0 Tank flush
Last Post: RandallM
0 High beam not working
Last Post: joe s
Last Post: 84rzv500r
0 My new deer rifle
Last Post: Whitewalls
0 1995 Manual
Last Post: jeffro57
0 Massachusetts 2022
Old 4th June 2012
x1torq21 x1torq21 is offline
Sportster/Buell Model: x1 lightning
x1torq21 is an unknown quantity at this point
Question need advice (assembly with NRHS 1250 kit)
so i installed the nrhs 1250 kit on my bike but when i put the rocker box on it doesnt sit flush. i turned the motor over till the push rods were at there lowest point. how can i make this work?
Old 4th June 2012
texbombboy's Avatar
texbombboy texbombboy is offline
Sportster/Buell Model: XL883R
Other Motorcycle Model: WR250F
Other Motorcycle Year: 2008
texbombboy is a splendid one to beholdtexbombboy is a splendid one to beholdtexbombboy is a splendid one to beholdtexbombboy is a splendid one to beholdtexbombboy is a splendid one to beholdtexbombboy is a splendid one to beholdtexbombboy is a splendid one to beholdtexbombboy is a splendid one to beholdtexbombboy is a splendid one to beholdtexbombboy is a splendid one to beholdtexbombboy is a splendid one to behold
put clay in the top of the rocker boxes to figure out where the rockers are hitting. Then go at those boxes in small steps until you have gotten enough material out of the way for everything to move. Which cams did you go with? Might give dan a call he can probably give you much better advice on the where and how much.
03 883R NRHS 1250 stg 3 04xl1200r heads 15 deg dome SE.575 Daytona twin tec lsr 2-1 works suspension storz rear sets
