0 Getting old is a bitch!
0 85 Ironhead, Kiffy Stand Question
Last Post: eddie XLX
0 Turn signals stopped blinking
Last Post: RandallM
0 Allegheny National Park III
Last Post: skien
0 Clutch Replacement
0 Rocketmangb
0 My new deer rifle
Last Post: kiwicafesporty
Last Post: 11B40
Last Post: speedyrette
Last Post: shtbskt
Last Post: Brad
0 Sportster S on the dyno
Last Post: Fivecats
0 1967 on FaceBook. Florida.
0 Tank flush
Last Post: RandallM
0 High beam not working
Last Post: joe s
Last Post: 84rzv500r
adjustment, freeplay, noise, pushrods, top end
Old 5th October 2013
Lockeshill's Avatar
Lockeshill Lockeshill is offline
Sportster/Buell Year: 75
Sportster/Buell Model #2: xlh 1200
Sportster/Buell Year #2: 90
Lockeshill has a spectacular aura aboutLockeshill has a spectacular aura aboutLockeshill has a spectacular aura aboutLockeshill has a spectacular aura aboutLockeshill has a spectacular aura aboutLockeshill has a spectacular aura aboutLockeshill has a spectacular aura aboutLockeshill has a spectacular aura aboutLockeshill has a spectacular aura about
Default side to side freeplay on pushrods? how much is acceptable
So I began hearing a rattling or clacking noise coming from the top end right side. The motor was totally rebuilt top and bottom this spring so figured the rods needed adjusting. When checking for freeplay I have none up and down and slight side to side on 2 of them. When I say slight I mean probably 1/16 both ways. There is no trace of binding in fact they feel like they spin a little too easily. So is that enough freeplay to warrant adjustment. Thx
Lock... ;Q
Robicycle's Avatar
Robicycle Robicycle is offline
Sportster/Buell Year: 1969
Robicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of lightRobicycle is a glorious beacon of light
Pretty sure as little as possible. They should be able to turn just but not be loose...look in the stickys for the info on adjusting your pushrods, should explain everything for you.
simeli simeli is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 69
Other Motorcycle Model: Sportster
Other Motorcycle Year: 70
simeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud of
None is acceptable!
You should have no side to side play.
I would look at the possibility of mismatched parts,
or extreme wear.
Lockeshill's Avatar
K. I will adjust and recheck that sideplay. Could that amount of sideplay cause rattling type noise coming from that area as described before?
brucstoudt brucstoudt is online now
Sportster/Buell Year #2: '03
yes.check to see if the lifter is moving,side to side,in the tappet block.
Lockeshill's Avatar
Thumbs up
Adjusted tappets and rechecked adjustment. Definitely fixd the minor freeplay side to side. Started her up and got to operating temp. Heard the same sound for a brief time and then it stopped. Is it possible my top end noise was coming from this as I did not touch anything else???
All I have to do is go for a rip tomorrow and see if it holds that way.
Thx to all
Old 6th October 2013
Lockeshill's Avatar
One more thing. What is the torque on those locknuts? I had a hell of a time getting all but one loose. Even rounded one a little bit. My Indy wrench must have cranked those bastards on there.
Dasrite Dasrite is offline
Sportster/Buell Model: SPORTSTER S
Sportster/Buell Model #2: Cyclone
Sportster/Buell Year #2: 1999
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1965
Dasrite will become famous soon enoughDasrite will become famous soon enoughDasrite will become famous soon enoughDasrite will become famous soon enoughDasrite will become famous soon enoughDasrite will become famous soon enoughDasrite will become famous soon enoughDasrite will become famous soon enough
I have had a tapping noise fixed by simply undoing the rocker shaft nuts and turning the shaft 180 degrees and retightening them again.
Lockeshill's Avatar
Cool info there dasrite. If the rattling comes back I will have to tweak my rockernuts and shafts. Any idea why the shafts would cause the noise?
