Last Post: Fivecats
0 Getting old is a bitch!
0 Allegheny National Park III
0 Sportster S on the dyno
Last Post: Fivecats
0 1967 on FaceBook. Florida.
0 Tank flush
Last Post: RandallM
0 High beam not working
Last Post: joe s
Last Post: 84rzv500r
0 My new deer rifle
Last Post: Whitewalls
0 1995 Manual
Last Post: jeffro57
0 Massachusetts 2022
33.4, fork, front end, ironhead, triple tree
Old 6th March 2021
hogsrear hogsrear is offline
Sportster/Buell Year: 1971
hogsrear is an unknown quantity at this point
Default 33.4 Triple Tree Rubber Riser Bushings
Hi all, I recently picked up these 33.4 trees for a project I'm working on. I plan to run the stock clamp riser and two piece buckhorn bars, but the top tree is obviously missing the rubber bushings. I actually had a spare set of repop bushings I bought a while ago on hand, but what is the proper way to install these? I know they usually stick out the bottom of the tree maybe less than a half inch. Tried driving one in with a mallet but wasn't getting anywhere. Thanks in advance.
1990 XLH Sportster 883
Old 7th March 2021
sungod's Avatar
sungod sungod is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 73
Default bushings
Are the bushings #56158-49? They have a metal inner and outer sleeve. Used on 54 to 72.
Old 7th March 2021
rejeanprimeau's Avatar
Bushing are press in, make yourself a gizmo with a threaded rod and washer. Also the bushing shall be a bit smaller 0.002". I like to freeze them with green loctite.
Old 9th March 2021
That worked! Thanks rejean
