28th March 2021
Posts: 66 Sportster/Buell Model: XL1200CA Sportster/Buell Year: 2016
Poll: Milwaukee-Eight Sportster Engine Size
If there is an M8 Sportster in the offing, what engine would you want?
- 883 or 1200cc is perfect for the Sporster
- 883 or 1300cc+ is required these days
- 883 is no longer required, larger engines only
I don't have the options to create a poll, but please vote anyway!
Cheers,
Chris
28th March 2021
Posts: 1,310 Sportster/Buell Model: XL883DLX Sportster/Buell Year: 1992
1. Best option
2. 1300+ Makes no sense, just buy a BT
3. Only for people who suffer from Small Penis Syndrome.
28th March 2021
What? Who told you about my diminutive genitalia?
28th March 2021
No one, you just did. I was merely refering to a syndrome
But seriously, I think if there ever will be an M8 Sportster they should keep a 'smaller' version like the 883. Get some decent power out that 883 to beat some Ducati Monsters. Keep the 1200 for cruising/touring purposes.
28th March 2021
Air-Cooled Forever
Posts: 3,400 Sportster/Buell Model: XL 1200 C Sportster/Buell Year: 2006 Sportster/Buell Model #2: (Prev.Own)XLH Milw.Spec. Sportster/Buell Year #2: 1981
I'd be good with 1000cc or 61 cu. in.
29th March 2021
Posts: 512 Sportster/Buell Model: XL 1200 S....X Sportster/Buell Year: 1999 Sportster/Buell Model #2: XR-1000 RX Sportster/Buell Year #2: 83 Other Motorcycle Model: SOLD - RZV500R/R1 hybrid Other Motorcycle Year: 1984
1000 or 1200...
1999 XL 1200 Sport RX, SE 7500 ignition, SE air filter, DynoJet, K&N, Cone Engineering 2:1 pipe, Storz Steering damper, with 2012 XR1200X perf forks, 3.5 x18" wheels front and rear, Galfer stainless lines, XR1200 4 piston front calipers, 18" Dunlop D404 130/70 and Dunlop trailmax mission 140/80-18 rear XR1200X perf shocks, 19/48 530 chain conversion, Dart Flyscreen, Antigravity LiFePO4 battery
1983 XR-1000S to XR-1000RX Project Build Thread
30th March 2021
Posts: 1,358 Sportster/Buell Model: xlh883 Sportster/Buell Year: 2001
To compete with Il Mostro, the Sportster is going to have to lose about a hundred pounds, and I don't see that happening.
My 883 was fine for what I used to use it for, and would easily cruise at 85mph (137kph) given low elevation and flat land.
However, some of the packs I ride in now like to maintain a speed of around 90mph (145kph) and 883s are actually against the rules. I cannot speak to why they are against the rules but my guess is because the 883 loses speed real quick when faced with things like hills, headwinds, and high elevation.
As far as big bore motors go, what's not to like? Maybe someone wants a 120-130hp motor in a smaller, better handling chassis, and they don't need it to live for 100k miles. Some people would rather be shot out of a cannon than squeezed out of a tube, to paraphrase the late Hunter S. Thompson. It doesn't say a damn thing about the size of their junk.
The fact you trot that old tired insult out says a ton about you though.
Have a great day!
Sent from my Moto E (4) using Tapatalk
30th March 2021
What old tired insult? I'm not aware that made one? I made a joke. You know joke?
"a display of humour in which words are used within a specific and well-defined narrative structure to make people laugh and is usually not meant to be taken seriously. It takes the form of a story, usually with dialogue, and ends in a punch line."
But if the cap fits, wear it...
30th March 2021
Posts: 91 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2006 Other Motorcycle Model: Yamaha FZR1000 Other Motorcycle Year: 1988
The M8 Sportster could have a balance shaft(s) (similar to M8 BT), and a slipper clutch, then solidly mounted to a new LIGHTER frame. 1200 and 883
2006 XL1200R in Yellow Pearl with wire wheel option; 30t trans sprocket; SE Heavy Breather a/c; SE II slip-ons; S&S IST ignition; 48 pilot, 185 main, CVP EZ-just mixture screw; HEL braided brake lines; Race Tech Gold Valves, Ohlins S36E shocks, Superbrace; Dart screen, Mustang Vintage Solo; JH570 cams installation underway.
30th March 2021
Posts: 208 Sportster/Buell Model: PanAmerica Sportster/Buell Year: 2021 Sportster/Buell Model #2: XLH Sportster/Buell Year #2: 1985 Other Motorcycle Model: Triumph, BSA,more Sportys
I can say, that after a winter touring the South n Southwest on a 2010 883 and 12,000 miles, it does get a little breathless on hills n higher elevations. However, with suspension upgrades, the bike handled well and was absolutely reliable. My vote...keep it simple, focus on one GOOD engine, 1000cc should provide enough power, I know my 85 XLH does.
Support your local ABATE
The number of kicks required to start a sporty are in direct relationship to the number of people watching.
