Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Engine Conversions
Last Post: Jeffmazz
0 Getting old is a bitch!
0 Allegheny National Park III
0 Sportster S on the dyno
Last Post: Fivecats
0 1967 on FaceBook. Florida.
0 Tank flush
Last Post: RandallM
0 High beam not working
Last Post: joe s
Last Post: 84rzv500r
0 My new deer rifle
Last Post: Whitewalls
0 1995 Manual
Last Post: jeffro57
0 Massachusetts 2022
Old 23rd March 2007
citified's Avatar
citified citified is offline
Sportster/Buell Model: XR1200
Sportster/Buell Model #2: FLTR
citified has a spectacular aura aboutcitified has a spectacular aura aboutcitified has a spectacular aura aboutcitified has a spectacular aura aboutcitified has a spectacular aura aboutcitified has a spectacular aura aboutcitified has a spectacular aura aboutcitified has a spectacular aura about
xb9 and xb12 are the same bore, putting a 9r crank in a 12r would get you a 9r. Sorry to burst your bubble.
Old 23rd March 2007
rottenralph's Avatar
Are the heads between the two different xb bikes the same. Valve sizes the same between the two xb bikes.
Old 26th March 2007
xl1200r's Avatar
xl1200r xl1200r is offline
Sportster/Buell Model: Buell 1125CR
Sportster/Buell Year #2: 1964
Other Motorcycle Model: Kawasaki Ninja 250
xl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura aboutxl1200r has a spectacular aura about
Read my first post again. I want to put in the shorter stroke 9 crank with the big-bore cylinders. Hence "short stroke with big bore".
No bubbles bursted.
Heads are identical between the 2 engines.
Old 26th March 2007
2003xb9R
Guest
Posts: n/a
Well I got at 2003 xb9r and want to put a 12 crank in it, do u want to just swap engines and ecm's lol?
Old 30th March 2007
citified's Avatar
No bubbles bursted.
sorry, I thought wrong. I too would like to do the 1050 kit, some day, After I blow it up anyway
Old 7th April 2007
xl1200r's Avatar
Kind of my boat - part of me wants an excuse to have to tear the whole thing down.
Old 7th April 2007
Sleeper Sleeper is offline
Sportster/Buell Model: XL883R
I considered that build also, but most of the professional builders I talked to, said the valve train is the limiting factor. To reach the HP levels you want would take reving the hell out of it.
Even so it would be cool to get a HD motor to rev like a NASCAR motor.
Old 6th January 2008
Streetpro's Avatar
Streetpro Streetpro is offline
Sportster/Buell Model: XR-750
Sportster/Buell Model #2: Sportster 89 ci.
Sportster/Buell Year #2: 1991
Streetpro is an unknown quantity at this point
I know guys from the Hillbilly-racing-team here in Germany combined an XB9 crank with a big bore set from Millenium tech. It turned out to be an 1170 cc "short-attack" bike with 100+ rwhp. Anyway I would guess 120+ rwhp out of 1200 cc is not good for all-around street-use.
I got these numbers from a 1430 cc = 87 ci square engine with radical cams and 11:1 CR.
Martin
Old 22nd April 2009
Stephen Lowry's Avatar
Stephen Lowry Stephen Lowry is offline
Sportster/Buell Model: 1988 XLH 1424cc
Sportster/Buell Year: 1988
Sportster/Buell Model #2: XLX iron head
Sportster/Buell Year #2: 1983
Other Motorcycle Model: Victory Vision
Other Motorcycle Year: 2008
Stephen Lowry is a jewel in the roughStephen Lowry is a jewel in the roughStephen Lowry is a jewel in the roughStephen Lowry is a jewel in the roughStephen Lowry is a jewel in the roughStephen Lowry is a jewel in the roughStephen Lowry is a jewel in the roughStephen Lowry is a jewel in the roughStephen Lowry is a jewel in the roughStephen Lowry is a jewel in the roughStephen Lowry is a jewel in the rough
If you had heads and ECM to support it, it would make a good race motor for AHRMA Pro twins formula 2.
XL's: You got love em, make em faster, handle and stop better as they get older: 116 HP & 105 lbs TQ, 88inch Axtell mountain motor.............Steve
