5 Terminology Sticky?
0 Hello from Murcia-SPAIN
Last Post: heyshott 81
Last Post: oupa
Last Post: Darkseacret
0 How to start a 1967 Sportster XLCH
Last Post: JackPrice53
0 XB9 crank?
Last Post: Curbside
0 Jutland 05-31-16
Last Post: slcharger
0 XR1200 belly pan on an XL?
Last Post: CT XR rider
0 POLL: Vance and Hines
Last Post: Bama Lee XLC
0 And so it begins......
Last Post: Texassporty06
0 Spokes or Mags
Last Post: Desertfox
0 Spokes question
Last Post: Doc308
Last Post: Nayra
0 Fuel Pump Problems
6 Is Your SPORTSTER...
0 How stock is your bike
fhilliard (78), paulmo (74), Beloved (48), Mr. Cro (48), Chopper Duke (40), Danny3nose (38)
Old 5th April 2018
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Default My Not So Stock 1980 XLS < Brakes >
Lets start with pictures 1st and explantions later under the pictures.
I also mention Sportsterpedia is free to use my images because after the summer Meet and greet in July. I will be making my own braided brake lines to replace the stock ones in the pics. I just feel I can get by with stock lines till after the meet in N.C. I mention the sportspedia thing because the ironhead brake section is pretty sparse. Edit < I mean the disc brake section >. Because drum brakes are covered pretty well.
Because I have money and time constraints. Since I am also in the middle of hardtail build also.
So this bike is originally from Nebraska. So rust and moisture and left outside in Nebraska has taken a small toll on her. But the motor and tranny is fine. I bought it from a drag racing family. No telling what is in the motor because I have not broke it down yet.
And I won't before the run. Because I wanna ride soon.
This bike is not even on the red lift anymore. I put it on my orange one. I'll post pics of it with the tins stripped off tomorrow.
Current Plan before July run is. New tires. Grease Bearings. Rebuild Carb. Clean rims < no paint or powder coat till after the run >. Take off chain and soak in diesel fuel in a tub for a few days. Then put it in another tub of used oil to soak for some days. Then re-install. It is a good o-ring chain. Install gator boots on the front end. Change my handles bars to longer drag bars and lengthen wires and lines and stuff so they reach.
Install daymaker head light.
New Battery.
Lube whatever needs lubing.
Later on this thread. I will document changing brake lines. Pulling oil tank and repainting it.
Any bugs that come up after reassembly. Like generator, points, etc........ Before the July run . I will try to take the time out and post pics and mention what I did to rectify those bugs also.
I may also show ideas later on. I have a solid timken bearing Mag wheel off a early softail that might go on this bike. I also have a old KZ650 dual disc 19 inch black spoke mag wheel that I might adapt for the front. But not yet. Just taking it slow and easy.
My paint I use on this will Be acrylic urethane using a top feed cheap ass harbor freight spray gun. Primer is plastic urethane based also. I won't farm that out. I still have some hot rod black left in my gallon can of paint I did the 1990 xl tins with.
Before I get flak about Black Bike again blah blah blah. I own multiple sleds. I like to keep the parts interchangeable between bikes without having to repaint them.
That is it for today. Off to do a 200 mile round trip < all day affair> to get the tins soda blasted.
Maybe pick up some primary oil and a oil filter also. I got a case of Valvoline 60 grade racing and still some Pennzoil 70 on the shelf. So no need for buying engine oil yet.
I live 2 weeks from everywhere.
New back tire is on the shelf already also. Hidden cookie. On my master cylinder shot.
You might notice my vacuum cleaner throttle cable adaption. My throttle cable holder drilled out allen bolt. Which is also a adjuster. You can barely see the head of the allen bolt sticking out in the pic. I will show a better pic later in the thread.
I don't live in a What If world.
Traveled to
Old 5th April 2018
Sadsack's Avatar
Sadsack Sadsack is offline
Sportster/Buell Model: Xlh
Sportster/Buell Model #2: FX
Other Motorcycle Year: 2014
Sadsack is a splendid one to beholdSadsack is a splendid one to beholdSadsack is a splendid one to beholdSadsack is a splendid one to beholdSadsack is a splendid one to beholdSadsack is a splendid one to beholdSadsack is a splendid one to beholdSadsack is a splendid one to beholdSadsack is a splendid one to beholdSadsack is a splendid one to beholdSadsack is a splendid one to behold
Not "everybody" has a disdain for blacked out bikes!
I've often run with the devil, but I've never made any deals....
Old 5th April 2018
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Iron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to beholdIron Mike is a splendid one to behold
Why are you concerned with flak? Its your bike. Paint it whatever you want.
Old 5th April 2018
kkbii kkbii is offline
Sportster/Buell Model: XL1250s,tax paid
kkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant futurekkbii has a brilliant future
I cant wait to see this one . See you in july.
Old 5th April 2018
MXHD55U MXHD55U is offline
Sportster/Buell Year: 1969
MXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant futureMXHD55U has a brilliant future
that's a quote, "I live 2 weeks from everywhere."
Old 6th April 2018
rokytnji's Avatar
Off to find me some sand blasters. My biggest problem out here. Everybody is far away.
2nd problem. Job is too small for oil rig sand blaster companies. Some already told me over the phone they don't do gas tanks.
Pics include my home made throttle cable setup. Truck bed has my hardtail tins, My wifes 1983 XLS stock tins, my 1980 stock/custom tins. Tomorrow will be carb rebuild day. It's a Bendix. I like those. They are easy peasy.
I am re-thinking changing the tires. They look like they will last the run. My pressure washer does not get real close to the metal and I use a fine spray tip and soap and water and a toilet brush to scrub the dust and grime off while the bike is stripped. I am real particular on how I use my pressure washer.
Headlight picture is to show where my new day maker head light is gonna be installed.
Vin is just fro grins.Orange lift is a old pallet jack from Tonka Toys < 20 bucks > when I worked there.
I bought a South Bend lathe <200 bucks> also when they moved to China. But I sold it to get funds to finish building my softail.
That is it for now. Gotta leave for Odessa Texas.
Old 6th April 2018
brucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant future
pallet jack lift looks pretty sturdy,does it need wood props?
Old 7th April 2018
rokytnji's Avatar
not really. But with 5 dogs roaming the shop lot. I can't be 2 careful.
The lowering style is to insert a rod and turn a valve. You can see the knob on the end of it and the hole it inserts into on the carb side of the bike.
I just don't trust my dogs is all. They are magicians sometimes. So, just added insurance.
Parts are now in Odessa to get blasted at 2 different places. I got the tanks at one place. The fenders at another place. Gonna see who I am gonna use again by what they charge me. No guesstamits were given. The owners were out to lunch and the girls don't know.
Old 7th April 2018
it pays to plan ahead.i swear sometimes dogs do things to try and impress their masters.
Old 7th April 2018
rokytnji's Avatar
I use the pin in the red lift religiously now . My dogs stepped on the pedal and brought it down once.
