0 rear master cylinder
0 Replacing Rocker Arm Bushings
0 New stuff from Harely
0 Range With EFI 2.1 Gal Tank
Last Post: jammantoo
7 Tach Drive Magneto by Burkhardt questions
Last Post: drumbrake
0 Stars and spanners?
0 Who's still riding???
0 Bendix / Zenith questions
Last Post: ezmerf
0 S&S IST Ignition
0 G,Day from Gods Country.
Last Post: Hobes
0 Both of my Sportsters going to the auction now
Last Post: Yellowstone Kelly
0 Fender Fit and Shinko 270 On Rear 4.50x18?
Last Post: drjperformance
0 remap. Y/N?
Last Post: oupa
0 oil plug 1959 xlch
Last Post: 72 Ironhead XLH
7 Starter Problems???
Last Post: maverick31210
0 Question on 2017 forty eight suspension
Last Post: Adam76
0 The O-FISH-ALL Red Sportster Thread
Last Post: Lone Rider
0 Spark Plug
0 1200 after market coils
Last Post: Metalhead86
Last Post: 60weight
0 ***DK Custom-22LR LED Run-Brake-Turn Lights-Universal Fitment***
0 DK Custom Products Streamliner Bullet Turn Signal Relocation Kits
0 Getting a face full.
0 Headlight Modulator
14 Iconic Parts that say it's a Harley!
Old 27th April 2018
barefoot barefoot is offline
Senior Bike Builder
Sportster/Buell Model: XR 750
Sportster/Buell Year: 1972
Sportster/Buell Model #2: RR 250
Sportster/Buell Year #2: 1976
barefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond repute
Originally Posted by doodah man View Post
Oh, I meant the plunger in the door that contacts the bottom of the shift cam.
We could start a pool, everybody put five bucks on their favorite failed part.
Then the Doc would come in, snag all the money, and run back to his cave laughing all the way
Old 27th April 2018
paulc paulc is offline
Sportster/Buell Year: 1976
Sportster/Buell Year #2: 74/5
paulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond reputepaulc has a reputation beyond repute
Hopefully five bucks is all it will cost in parts
Yoshi is coming over Saturday morning and the trans will be pulled then so there is 24 hours more betting time left.
Paul
Old 27th April 2018
ezmerf's Avatar
ezmerf ezmerf is offline
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1980
ezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud ofezmerf has much to be proud of
Well I'll stick with my story.The high pitch whining the metal on his fingers looks like gear material I say it wasn't setup right.
Murphy's Law :vvet:
Old 28th April 2018
Senior Bike Builder
Originally Posted by ezmerf View Post
... the metal on his fingers looks like gear material I say it wasn't setup right.
Most likely from the dogs bouncing off each other at speed, when it wasn't shifting. It could have been set up perfect but some little part broke, trashing the shifting, which leads to ... Now you could say the mechanic should have magged every part to eliminate any old junk from breaking, but if we could predict the future Parnelli woulda won Indy.
Old 28th April 2018
mct496's Avatar
mct496 mct496 is offline
Sportster/Buell Model #2: 84 xl paughco rigid
Other Motorcycle Model: 70 xlch
mct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to allmct496 is a name known to all
Default That would be a good idea
Would it not be best to check his end play on main and counter shafts before he pulls trans since the indy missed the torque?
Id check out the doc's shifter blueprinting thread in the meantime and if you can get your hands on some big twin top hats nows the time to upgrade and a hardned camplate would be nice too
Old 28th April 2018
yoshi came over today and here is a summary of our morning:
With the clutch loaded we tried to check mainshaft endplay but the shaft wouldn't turn or move at all so the dial registered nothing.
We couldn't check countershaft endplay as the plug on the end wouldn't come out.
Next we undid the trapdoor bolts and took out the trans:
We measured clearances and they were as follows:
C/S 2nd-3rd 33-35thou
C/S 3rd-1st 33-35thou
M/S 2nd-3rd 52thou
M/S 2nd-4th 58thou
Mainshaft looks bad here but in fact when cleaned up everything looked good except 2 things - M/S thrust washer and shifter fork shaft.
The M/S thrust washer was 85thou thick. EDIT: a bit scored but NO heat marks as I said at first.
Slight scuffs on gear but nothing of note. Gears, shafts and tower parts all looked fine so no pics taken.
Pin that stops thrust washer rotating doesn't look wonderful:
Mainshaft trapdoor bearing has some movement:
https://www.youtube.com/watch?v=zQ171fzedgI
The shifter fork shaft wasn't a tight fit in the trapdoor:
https://www.youtube.com/watch?v=bOr-slCC49s
Also at the case end of the shaft there was a black bung which seemed held in place with silicon of some kind:
My other engine has a metal plug there which I presume is 16285-48; Plug, shifter shaft. It is metal and looks like this from the outside:
This engine however just had the black plug, nothing that would stop the shifter fork shaft, that isn't tight in the trapdoor, from moving left to right. The shaft has some scoring, this pic was taken as I pushed it back and fore through the case:
Some burrs around the trapdoor hole it sits in. Think this is the right pic but not entirely sure :
Trans was reassmbled and the 85thou M/S thrust washer was temporarily, to see what would happen with endplay, replaced with a 60thou one. Trapdoor bolted back in and then we found:
M/S endplay 15-16thou
C/S endplay (plug was out now) also 15-16thou
That's where we stopped. went and to the pub for a pint of Doombar, well earned yoshi mate, many thanks:
I learnt a lot today and now will ponder things for a while before deciding where to go next. Thoughts gentleman please.
Paul
Old 28th April 2018
yoshi's Avatar
yoshi yoshi is offline
Sportster/Buell Year: 1971
Sportster/Buell Model #2: FXRS-SP
Sportster/Buell Year #2: 1985
yoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud ofyoshi has much to be proud of
The thrust washer with the heat marks wasn’t your one Paul, it was one from the box of stuff I brought with me.
Old 28th April 2018
Woops, thanks yoshi, I'll edit my post accordingly
Old 29th April 2018
Any thoughts anyone on what yoshi & I found yesterday?
Paul
Sent from my SM-G935U using Tapatalk
Old 29th April 2018
deguireb deguireb is offline
deguireb has disabled reputation
Hi Paul, Sorry to hear about this problem, I have my transmission out now and collecting parts for the C ratio update. Having second thought now though. I am also a rookie so hopefully you get some guidance from others with experience soon. I'll be monitoring this thread closely, thanks for documenting it so well. Regards, Bryan
