0 ***DK Custom-Limited Time Savings on ALL LED Lighting-See & Be Seen***
0 1200s mid throttle stumble
0 Headlight Modulator
0 XL883L 2006 coughing and backfiring
0 oil plug 1959 xlch
7 Tach Drive Magneto by Burkhardt questions
Last Post: T.B.Road
Last Post: moparnut72
0 Spark Plug
0 S&S IST Ignition
5 Jiffy Standing
Last Post: 83XLX
0 Do you like Brazilians???
Last Post: Bama Lee XLC
0 Both of my Sportsters going to the auction now
0 Filters
0 New stuff from Harely
0 Getting a face full.
0 In PA Or Nearby
7 Starter Problems???
0 G,Day from Gods Country.
Last Post: Blowupster
Last Post: maverick31210
0 1200 after market coils
Last Post: Metalhead86
0 71 -80 magneto
Last Post: T.B.Road
0 Oops.... Nicked the Steering Stem
Last Post: Sadsack
0 Bendix / Zenith questions
Last Post: randy3934
Last Post: kmul
6 What gasket sealer goo do you like?
Last Post: KCinSB
  #61
Old 18th May 2018
Dave L's Avatar
Dave L Dave L is offline
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Kawasaki Vulcan 700
Other Motorcycle Year: 1985
Dave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant future
Iron I had changed my thoughts when they held liquid. My bad!
Old 18th May 2018
needspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud ofneedspeed has much to be proud of
Originally Posted by Dave L View Post
…... Even the machinest noticed the incorrect crosshatch...….
I don't think the cross hatch from the hone was incorrect, but never honed at all. Just bored.
Look at the last pic in post #25. I've never seen a hone leave a pattern like that no matter how it was used.
Old 19th May 2018
Dave L's Avatar
Need speed. I think he lowered the piston and went in there with some sandpaper thinking he was doing some good to help seal the rings. An old small engine repair trick.
Old 21st May 2018
Dave L's Avatar
My home made valve spring compressor. Guides were tight with no play.
Old 21st May 2018
chevelle's Avatar
chevelle chevelle is online now
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
Are those collars aluminum?
Old 21st May 2018
Dave L's Avatar
No everything is steel. I only tacked it as I didn't want to ruin a Wilton c clamp. In hindsight I should have put it on the other end. But it works for now.
Old 21st May 2018
spacecoast spacecoast is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 1989
spacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to beholdspacecoast is a splendid one to behold
Chevelle is referring to your valve collars. The part the keepers hold in place.
Old 21st May 2018
Dave L's Avatar
They are steel. Unless they make an aluminum magnet. Stainless steel valves, steel guides, steel keepers. I am going to pick up some valve compound and clean the seats up a little. They all look good, and as previous were holding liquid. But figure may as well at this point.
Old 23rd May 2018
Dave L's Avatar
Found out last night the PO took some sandpaper and did what he thought was roughing up the cylinders. I told my buddy to tell him that he did more harm than good. Crosshatching to help seat new rings is not circular surface scratches. Hope this prevents him from doing that again!
Old 23rd May 2018
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Hey. You gotta take the bad with the good some times.
Sign of a stand up dude is how well he rolls with adversity.
If I was in your shoes. I'd roll with a KISS refurbish on those jugs and heads. Throw in some some unleaded seats. Edit: If a good machine/head shop is close by. If not. Roll with the originals.
Call it a day. Ride the crapola out of it.
I don't live in a What If world.
Traveled to
