0 New from the cold north...
0 Old man walks back into a forum..
0 First XL - XLCH or XLS?
Last Post: Magneto Sportster
0 Broke Down and Ordered an Optima Ignition Kit
0 mikuni vm38/9 on a 2001 xlh
0 Jetting 42 mikuni
0 fork seal
Last Post: wrkdWS6
0 Harley Hacks & Tech Tips - Build It Better™ - So Much Useful Info!
0 83 Sportster basket case
Last Post: joe s
0 Clutch Slipping at higher RPM
0 charging
0 Helmets Please...
Last Post: gusm2
0 forward controls for an 81
0 Allegheny 2023
Last Post: wardie
0 72 xlch is overcharging... bosch mechanical reg
Last Post: rocketnorton
0 R.I.P. Tina Turner
Last Post: MDT
0 Axle-grease question
0 Disappointed with Eastern shift forks
Last Post: davixlrtt
0 Highway Pegs recommendation
Last Post: Yochstein
0 Passenger backrest for 07 883?
Last Post: Mike1nw
0 Registration question
0 "S" model specific Q&A
Last Post: Model H
0 More advice.... (2007 Roadster Seat On 2011 Superlow?)
Last Post: wiltybob
0 .551 Cams in an EFI 1200
jeffcahill (70), jeebus (55), cdepaola (53), RubenAlonzo (53), chida66 (48), schneck0341 (46)
Old 22nd March 2023
Hightop Hightop is offline
Other Motorcycle Model: FLH
Other Motorcycle Year: 1955
Hightop is an unknown quantity at this point
Originally Posted by conv90 View Post
very short forks , very short shocks , 6000 rpm and dumb the clutch and stock tires, advanced position seat? Is this the recipe to not flip the bike while letting the clutch lever? With my sportster if I let the clutch like this, I can't avoid tipping over..
When you use short rear shocks, the swingarm pivot is much lower than the center of gravity, all your power is pushing here, forcing the front up. Better to use shocks resulting in a level swingarm angle, IMO
If you tie the front end down instead of lowering it, you force the bike to raise the weight from the lower legs, brakes, and wheel and tire right from the hit, making a wheelie more difficult. If it's just lowered, you'll get an inch or so of extension before making it do the heavy lifting, and it's already moving in that direction, kind of like it's easier to wheelie if you pull back on the bars when you crack the throttle to get it moving
Old 22nd March 2023
Don't "dump the clutch". Slip the clutch to control wheelspin / wheelies. Adjust your launch rpm so you can pretty much hold the throttle wide open thru first gear while slipping the clutch.
Old 24th March 2023
conv90's Avatar
conv90 conv90 is offline
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Sportster
Sportster/Buell Year #2: 1975
Other Motorcycle Model: Buell S1 W
Other Motorcycle Year: 1998
conv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond reputeconv90 has a reputation beyond repute
Correct. I see now the video that alla are with front tied.
About the rear it seems they are all with very short shock with the pivot point of the swingarm slightly lower that the center of the wheel (probably almost rigid like ).
1990 Sportster Axtell 90 ci, CP Carrillo 3.875 30° deg pistons,STD Heads, 615V2 RedShift cams, HSR48,
Carrillo 6.938 rods (All HammerPerf)
Hammer Billet Sledge air filter
Hammer Billet Manifold.
160/60ZR17 rear on Akront 5.50" Alu rim
100/90-19 front on Akront 2.50" new Alu rim
YSS 13.75 rear shocks
1975 XLH almost stock
1998 Buell S1W almost stock
Old 24th March 2023
conv90's Avatar
I was referring to the video. It seems they are all skilled guys.
They dump the clutch, you can see for example the second pass of the guy in the left lane letting the lever during start.
There is no squat , the bikes seems rigid.
madnss madnss is offline
Sportster/Buell Model: 883 Xl
There is only one recipe and you have to find it yourself. I sent my 17 year old son on a 6000 rpm launch, only because I firmly believed I knew what the bike was gonna do. It did both with my combo, it ran like hell and it also blew the tire off.
Imho any bike with an adjustable clutch has the advantage.
Look more closely. As he stages he lets the clutch out to where the friction point starts and then feeds it out when he launches.
Their rules must prohibit struts. The rear shocks many are running appear to be bottomed, on the bump stops, effectively struts. Along with tied down forks. It looks like a pretty serious bunch.
wrkdWS6 wrkdWS6 is offline
Sportster/Buell Year: '06
Sportster/Buell Model #2: XLCH Drag Bike
Sportster/Buell Year #2: '63
Other Motorcycle Model: XLH
Other Motorcycle Year: ‘79
wrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond reputewrkdWS6 has a reputation beyond repute
Them boys can ride, fun to watch them in person. They really get those bikes moving out the hole.
rejeanprimeau's Avatar
You need at least one flip to start understand why you have a clutch.
