0 Transmission drain plug
Last Post: roadsterboy
0 1975 Sportster
Last Post: alsfarms
0 2003 Custom 1200
12 I caught a carburetor THISSSSSS rare
0 Clutch issue
Last Post: Fivecats
Last Post: SophieWillow
0 Indicators not flashing
0 Gear indicator missing
Last Post: duffy
0 1982 rubber oil hoses
Last Post: Porkchop9
0 1975 Sportster
Last Post: Bikeaholic
Last Post: Animosity
Snuffy (72), cabby58 (63), SmoothyB (54), johnnyB (52), cayey (51), BIGschwerm (45), chief (45), Sporty Accorn (45), Muddypunk (36), Andreas (34)
carb, cv carb, fuel
  #51
Old 18th June 2008
Terp84Alum's Avatar
Terp84Alum Terp84Alum is offline
Sportster/Buell Model #2: Yamaha Raider
Sportster/Buell Year #2: 2010
Other Motorcycle Model: Yamaha FZ1
Other Motorcycle Year: 2008
Terp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to beholdTerp84Alum is a splendid one to behold
They suck. Fix the CV.
Ken from Maryland
**RIP MR. JIMI & JOHNNY G**
Old 18th June 2008
NC_REDNECK_1981's Avatar
NC_REDNECK_1981 NC_REDNECK_1981 is offline
Sportster/Buell Year: 1988
Sportster/Buell Model #2: xlh
Sportster/Buell Year #2: 1984
NC_REDNECK_1981 is an unknown quantity at this point
what cv carb is better, the older one like came on my bike or a newer model with an acc pump?
Old 18th June 2008
biknut's Avatar
biknut biknut is offline
biknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to beholdbiknut is a splendid one to behold
I think it would be good to get a newer one. Yours is the very first year they had the CV carb and it's probably worn out. The accelerator pump was an improvement. A lot of times you can get a used take off carb for cheap at the Harley shop if you ask.
Completely stock except for, Branch #5 heads & 10.5:1 JE pistons, Red Shift V531 cams, S&S Super E, ThunderJet, V&H Sideshots, S&S Flywheels, Dyna 2000i, Stortz 55mm Inverted Fork, JMC Swingarm, Works Performance 12.5" Shocks, PM 4 Piston, PM wheels, 18 x 150 R tire, Custom Belt Drive Conversion, Still Has Original Nut Behind The Bars
Old 18th June 2008
wilbur's Avatar
wilbur wilbur is offline
Wait...What?
Sportster/Buell Model: 88 inch modified
Sportster/Buell Model #2: iforgot
Sportster/Buell Year #2: 80's
Other Motorcycle Model: crs
Other Motorcycle Year: 80's
wilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to beholdwilbur is a splendid one to behold
The CV is a great all-around carb. I've got one w/pump if you are interested. It's an 03 model.
Old 7th July 2008
i think i figured out my problem. i removed the drag pipes and put a set of stock headpipes with screamin eagle slipons on it and rejetted the carb. it has the 45/200 jets in it now and i cleaned the hell out of it. trash in the carb?????????? float sticking??????????? hell i dont know, honestly i dont care.im getting 55 mpg its runs great and has a hell of alot better torqe curve now. i changed the look of it also. check it out and let me know what you think.
http://i298.photobucket.com/albums/m...1/SN850629.jpg
http://i298.photobucket.com/albums/m...1/SN850626.jpg
http://i298.photobucket.com/albums/m...1/SN850627.jpg
http://i298.photobucket.com/albums/m...1/SN850628.jpg
Old 7th July 2008
biknut's Avatar
That looks very nice. Glad you got it running good.
Old 7th July 2008
so am i. trust me that had me puzzled
