0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Fifty150
0 Off Road Lights
Last Post: Fifty150
0 78 Ironhead switchgear parts
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 HSR idle mixture screw
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
0 Should I buy a Sportster??
Last Post: riceburner
0 Q cams in 73 xlh ??
0 Front deflection
Last Post: denguy
0 what are acceptable oils for primary ?
Last Post: Fivecats
0 Ran out of gas.
Last Post: Hellbent_4
0 Best seat for long rides
Last Post: Diogenes415
0 need help with 68 XLH
0 2021 Iron Butt Rally
black pearl (77), SDREDD (60), pig (58), BonRu (56), wandawells42 (52), cbass (48), HawkeyeTX, SxysCowboy (38)
cam timing, generator, pinion gear
Old 8th August 2019
olander olander is offline
Sportster/Buell Year: 1967
olander is an unknown quantity at this point
No damage to the valves. Actually no damage at all anywhere. Guess I was lucky this time
Old 8th August 2019
Sportster/Buell Year #2: '03
I've also put a valve impression into a piston dome.the steel valve survived the pushrod bent.i've bent valves when they got stuck in the new guides.steel valves colliding will not survive.all 4 brand new valves had to be replaced.
Old 11th August 2019
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond repute
A spun press fit is now a worn press fit. I've not personally degreed then TIG welded cam eggs to shafts as I don't mess with racing 45s etc, but I'm sure someone here has who can offer advice. Unless the cams are expen$ive aftermarket parts you REALLY need to save I'd replace them as a set. Good time to upgrade..
Old 12th August 2019
I ended up reading this thread: http://xlforum.net/forums/showthread.php?t=1222275
So I will replace my PB cam for the original B cam. Since I’m just cruising with by bike I think they are a better fit.
